Old 06-11-2006, 07:30 PM
justxkyle justxkyle is offline
range issues
does andone know how to improve the range of the car?
i can only get about 10 feet before it cuts out and dosnt respond.
how can i improve o this?
Old 06-11-2006, 07:48 PM
Jazz32
Make sure you have fresh batteries in the remote. Also, do you have more than one set of crystals. I've found that even sets of the same number crystal will have poor range. I have about 3 sets of of the #4 crystal and certain ones work together and others don't.
Old 06-11-2006, 08:18 PM
i only have one set of crystals, the ones that came with it, but thre is fresh batteries in both car and remote.
even stil should it not go more then 10 feet?
seems kinda stupid if it dosnt.
Old 06-11-2006, 09:51 PM
flamehead_16's Avatar
flamehead_16 flamehead_16 is offline
Naruto Champion
make a longer antenna
People come and go, but no one stops and looks.
Black/Red F150- Lift kit, body lift.
Black Camaro- 6th cell dragster with custom tires.
Blue Mustang-Slammed wheels
Black Hummer- Everything
Old 06-13-2006, 06:43 AM
i dont want a longer antenna though.
i just though it would go more then ten feet.
seems pathetic.
Old 06-13-2006, 12:09 PM
Naruto Champion
you get wire the same thickness as the stock antenna and it will help make it go longer distances because that is what i did and it worked
Old 06-13-2006, 06:34 PM
then what do i do with this new wire?
Old 06-13-2006, 09:53 PM
Jazz32
There is a "range repair" some people sell. It replaces the two inductors for the RF system. It involves soldering the old ones off and replacing them.
I haven't researched it much, but you can fry an inductor and it will kill your range. That could be what happened in your case. Search for it and see what you find.
and yeah.... bigger antenna should be unecessary. We know there is a problem to begin with, fix the problem first.
Old 06-14-2006, 03:55 PM
is there anything that i can do thats much easier and that i can do at home to improve it?
Old 06-14-2006, 05:37 PM
Naruto Champion
custom antenna is the easiest thing
Old 08-28-2006, 12:25 PM
NEO-R NEO-R is offline
Would guitar string work? My car has NO antenna!
Where did the time go?
Old 08-28-2006, 02:46 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Yes, works very well in fact.
The thickness of the wire doesn't matter. The frequency of the signal responds to the length of the antenna. The length is matched to the wavelength of the signal, or fractions thereof.
smart range question rydzjunior XMODS Mods and Projects 0 03-03-2007 07:39 PM
ZZMT Remote Range 88-Fiero-GT ZipZaps Mods and Projects 1 10-09-2005 09:03 PM
Range Issues... SupraKid89 XMODS 2 01-03-2005 11:01 PM
Question about range 05WillysJeep ZipZaps Monster Truck 2 12-11-2004 04:43 PM
range of 27 MHz versus 49 MHz gRC ZipZaps 12 09-30-2002 06:33 PM
