Old 03-28-2006, 08:29 AM
Rez Rez is offline
Modded.... tool box?
I ran out of stuff to do to the car, so I decided to start modding my tool box. I added power terminals (12 VDC), a battery from a UPS which can run my battery chargers if there's no AC power available, a cold cathode light, and the latest addition, a cooling fan.
We all know how hot an xmod can get after you burn down a set of batteries at the track. When the addition of a heat sink didn't cool the car enough for my liking, I decided I needed to add a little something. Next time I'll remember to vac out the dust before taking pictures. There are holes drilled in the box in front of the CC light, which makes the blue glow you see behind the box in the dark shot.
So what have you guys done with your box?
http://www.deviantart.com/view/30707703/
http://www.deviantart.com/view/30707731/
http://www.deviantart.com/view/30708082/
http://www.deviantart.com/view/30708288/
Rez
a7i20ci7y
Seven Cities RC
Old 03-28-2006, 08:32 PM
NEO-R NEO-R is offline
Nice box set up. Out o' curiosity, how did yu attatch the heat sink tu t3h motor? Really cool way yu set yur box up though, and a good idea tu put in that fan tuu.
Where did the time go?
Old 03-28-2006, 09:46 PM
Rez Rez is offline
The heat sink is a little aluminum sink that radio shack sells for a buck and change. There's one screw hole in it, and I put a screw through that hole and into the metal xmods heat sink. The ribs in the xmods sink holds onto it pretty well, but I also glued it for good measure. I had to drill another hole large enough for the front screw to pass through in order to take the heat sink off. Mounted as is, it fits right under the lancer body without modification. On my friend's mustang I had to grind the back of the fins down to fit.
Padon the dirt, haven't had a chance to clean it up after my last run.
http://www.deviantart.com/view/31038877/
http://www.deviantart.com/view/31038910/
Rez
a7i20ci7y
Seven Cities RC
Old 03-28-2006, 09:51 PM
Aw crap. that meanz that I either have tu find a way tu order stuff online and get a motor heat sink and attatch it that way, or buy the ratshack heat sink and "creatively edit" it...
Highly modded crawler Hildy ZipZaps Monster Truck 3 07-11-2006 06:04 PM
"Quick" fet modded SE video bdebde ZipZaps SE 18 12-27-2003 06:15 PM
lamborgini set and a fet modded car boho Bit Char-G / MicroSizers 4 10-03-2003 12:25 AM
my modded zip vs. all my other cars natedogg4674 ZipZaps 0 11-04-2002 05:32 PM
