Go Back   TinyRC.com > 1/64 and Smaller > ZipZaps, ZipZaps SE > ZipZaps Mods and Projects
Old 03-26-2005, 12:23 PM
GrandRC's Avatar
GrandRC GrandRC is offline
Exclamation My ZZ only runs for about 45 seconds now. help?
my ZZ only runs for about 45 seconds(if im lucky a minute). help! plz!
when life gives you a battery, make something explode!!!
Old 03-29-2005, 08:11 PM
I-luv-Goin-Fast I-luv-Goin-Fast is offline
Well,
I can help but I need some info.
What mods have you done?
What size battery do you have?
What motor and gear set do you have?
Is it a plain zz or a zzse ?
I will reply as soon as these are anwered.
Shane
Old 03-30-2005, 12:34 PM
GrandRC's Avatar
-different antenna
-front skid plate
-stock zzse battery
-12:1 gear ratio
-microsizer clone motor(i think this is why)
thats it.
Old 03-30-2005, 04:48 PM
well, it should not be the MS motor because A MS only has a 50 mah battery. If the antenna is on the car then you could have fried your pcb when you where attaching it.
Not fully sure though
Shane
P.S. the zzse only has a 70 mah battery, powering a motor and the lights should kill the battery pretty fast
I would reccomend upgrading to a 100-120 mah battery or just dual celling it
Old 03-30-2005, 04:49 PM
oh yeah try double charging it or changing the batteries in your charger
It may not be getting a full charge
Old 03-31-2005, 11:21 PM
GrandRC's Avatar
ive been keeping time on the charge its a full minute. and my solde3ring iron doesnt work anymore. it just died. (death music) lol now i cant edit the antenna now cuz i dont think the antenna is even touching the pcb board. also where would i get an extra battery for a zz without buying a whole new zz? or where can i find a 100 mah or more battery?
Old 04-17-2005, 05:50 PM
send me ur info and i will send u 1
Shane
have 3.8 motor, runs like a 1.0 first time use. My clone motor is fastest i have. pakiplaya Bit Char-G / MicroSizers 13 12-15-2002 01:28 AM
Help!! Motor Runs When I Charge My Bit! Chris Bit Char-G / MicroSizers 1 11-24-2002 09:25 PM
My ZipZap now runs circles around my Bit! (dual batt success) caver01 ZipZaps 16 11-05-2002 11:22 AM
Bit runs faster in reverse....?! Crisp_Rapper Bit Char-G Parts and Hop-Ups 3 08-29-2002 12:10 PM
