Old 03-22-2005, 09:50 PM
gorbasho gorbasho is offline
how to raise?
this may sound weird, since many of u want to do the opposite, but how can u raise an xmods ground clearance?
i race mine outside, where there are many bumps waiting to eat your front bumper, and the paint off the side skirts and rear bumper
Yellow Skyline: S2 9-tooth motor, AWD, hard springs front, medium springs rear, custom graphics, CF drive shaft, CF front and rear upper decks, transparent chassis, wheel shims, white airbrushed rims (stock ones). SOON: black paint
Old 03-22-2005, 10:11 PM
broke ess supra broke ess supra is offline
hmm well if you want to jack up the back end of the body you can use a yellow bushing and a longer screw on the body mount clip. For actuall chassis ground clearance you can try dremelling some lego tires...i have heard of people doing this...you probably can't put the body on after this though.
My best suggestion is to go to a tennis court because i have broken a lot of parts(steering knuckles, cupjoints, front body clip, rims) on my rocky street. plus on a tennis court you can set up a track, drag race, practice turning, and not worry about cars
Old 03-23-2005, 01:02 PM
HammerZ's Avatar
HammerZ HammerZ is offline
Thrasher
You can do that to the front clip too, but it also makes the front shocks stiffer as well. Think all it will do is lift the body up some.
Old 03-23-2005, 01:12 PM
dragon4450's Avatar
customanix
also you could try to adapt some overland wheels to fit. the lift with the wheels will give you more than enough height.
Old 03-23-2005, 08:46 PM
anyone know when the cXp site will be back up?
Old 03-23-2005, 11:05 PM
i have a lot of questions about lithium since im a major newbie to the xmod aftermarket.
1. Where do u attach the micro plug on lithium quick kits?
2. can i trust this $10 quick kit? http://www.teammnm.net/liionquickinstallkitup.htm
3. what do u have to do to install a pro kit ?i heard about sodering and drilling, which i probably couldnt do.
Old 03-23-2005, 11:37 PM
dragon4450's Avatar
customanix
1. the same place where the stock battery holder is soldered.
2. its a quick kit, kinda hard to screw up 2 battery holders and some wire. just to make sure you know it does not include the cells.
3. solder the lead plug onto the motherboard and drill holes into the chassis where you can run zip ties to hold the batteries down.
Old 03-24-2005, 06:44 PM
if i dont wanna soder on a pro kit can i just cut the original battery wires and twist them together with the new wires?
Old 03-24-2005, 10:52 PM
dragon4450's Avatar
customanix
yah you could do that but you need to come up with a way to make sure it wont come apart.
Old 03-25-2005, 09:35 AM
heat shrink
Old 03-25-2005, 09:54 AM
rssjib rssjib is offline
Too many XMODS
Check out the FAQ on Li-Ions at AtomicMods.com...
It should answer all of your questions regarding this.
RSSJIB
(2) Yellow Skyline GT-R: AWD, AtomicMods 180S motor, Li-Ion, CF driveshaft, suspension, bearings
(2) Black Skyline GT-R: AWD, Stage2 motor, Li-Ion, suspension, bearings
'04 Mustang: AWD, AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: stocker
(3) STi WRX: AWD, CF chassis, AtomicMods SS130, bearings, body kit, Li-Ions coming
Black RSX: AWD, Stage2 motor, suspension, bearings
Silver RSX: stocker
Red Supra: AWD, Stage2 motor, suspension, bearings
Silver Supra: body kit, Li-Ions soon
(2) 350Z: body kit, Li-Ions soon
NSX: body kit, Li-Ions soon
'65 Mustang: body kit, Li-Ions soon
_________________________
"rehab is for quitters"
Old 03-25-2005, 09:56 AM
Too many XMODS
Here is a picture of one my Li-Ion chassis'. You can see the Deans connectors on here...I also upgraded the wire coming from the board, but you don't have to.
RSSJIB
Silver RSX: stocker
Old 03-25-2005, 01:28 PM
im trying to get lithium but dont want to solder, which is why i need ways to install a prokit w/o soldering. if thats not posiible or wont work too welll then ill go with a qucik kit. 1 thing is the qucik kit on atomic mods has no plug, u jjust twist it with the factory wires, but i found a cheaper qucik kit at team mnm, but it has a plug. what do i do? this is the quick kit: http://www.teammnm.net/liionquickinstallkitup.htm
Old 03-25-2005, 02:13 PM
Too many XMODS
I guess you could cut the Deans connector off and twist the wires together... that would work. Do you know anyone who could help you solder it? That would be so much better...
RSSJIB
Silver RSX: stocker
Old 03-25-2005, 03:28 PM
no i dont. could u answer my question on the previous post? aobut the qucik kit having a deans connector
Raise your Zip Zaps Lestertech ZipZaps 3 07-22-2003 10:00 PM
wtt raise tiger bit wun For Sale/Trade 15 03-11-2003 10:55 PM
Monster Raise Tiger hangbot Wild Char-G 6 02-04-2003 06:46 PM
Anyone have the raise version of the Wild Char-g? DisfourDan Wild Char-G 3 01-02-2003 08:52 PM
