Old 01-31-2005, 01:26 AM
GmKiller331 GmKiller331 is offline
Newbie Question concerning the differentials?
I see that on a few of your cars you have what appears to me the AWD kit on the front and rear like in this pic below.My question is why?Is the white differential inferior to the red for some reason?Ive read every sigle thing just about on this site concerning x mods and ive not seen it discussed.
Why not the white differential?
Old 01-31-2005, 02:57 AM
I have a beach ball...
In the AWD kit, you get two new differentials. The front one, which is already in the new front bulkhead you get, is a normal gear diff just like the stock rear diff. The rear one, however, is a limited slip ball differential. It's up to you, but IMO, the ball diff greatly increases the handling characteristics of the vehicle.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 02-02-2005, 04:03 PM
mastersmite mastersmite is offline
May the force be with you
Send a message via AIM to mastersmite Send a message via Yahoo to mastersmite
The red differential makes it alot easier to launch really well and to drift, basically, it allows better traction, because it does not stop the motion of one wheel when you barely touch it like on the white one. if you twouch the wheel, when you have the red one installed, you will feel the car pull hard and still go, the wheel will not stop unless you use very excessive force.
Moege die Macht bei dir sein
Yellow 2004 NSX
Stage 2 Blue 11tooth SB hybrid
blue springs in back, yellow in fornt
AWD
Ball DIfferential
Duct-tape Autobra
Old 02-10-2005, 12:38 PM
moddog moddog is offline
While what Murc and the master have said are true, you can alter the stock white diff to behave just like the AWD red one. One way is to pack it with AWD grease, or chapstick or play-dough. Ball diffs will go out over time, especially when if you are gonna run crazy power and motor such as anything with the lithium io / poly combo. I run a white diff in my AWD with the yellow arms. Matches the yellow skyline body.
Old 03-13-2005, 07:17 PM
adiosk8r13 adiosk8r13 is offline
im capital 1"s CE NO!!!
Or u can take apart the white differential and put clay inside the little gears and jam them causing the same effect as the red differential.
if you have ever stared into a can of
orange juice because it said concentrate you might be a redneck...
Old 04-01-2005, 05:10 PM
Rampage925 Rampage925 is offline
Will This do what I think it will?
If I where to take my stage 2 white 8 tooth gears (more torque) and pull them off and install them onto my stage 2 blue motor (highest power)? Would that take some power from the blue motor but at the same time give a harder torque/launch? Giving the car the most power I can and at the same time pulling some torque out of it as well so it's not slow off the line. Although I don’t think it would get the most torque you can get from a stage 2, I still think it would get a good mix of torque and horse power. Any thought, suggestions or advise? Thanks.
Old 09-12-2005, 05:49 PM
Xracer89 Xracer89 is offline
Send a message via AIM to Xracer89 Send a message via Yahoo to Xracer89
Ya if you have a stock car then ya go with the red ball diff, BUT if u have like Li-ions or better then a stage 2 motor then you want to stay with the stock gear diff... Only becasue the red ball diff with go out and eventuly wont work at all...
Silver(and a white) Toyota Supra,
Black Skyline too
FATBOY HC motor (yellow pinon)
V2.2 chip
Locked Rear Diff
Li-Ions
AWD
Motor Wire Upgrade
Is this normal? (newbie question) WSPFreak ZipZaps SE 12 12-29-2004 12:38 AM
Quick newbie question... SRTFAN XMODS 3 09-08-2004 09:06 AM
newbie here.... a question! initiaD Bit Char-G Parts and Hop-Ups 6 12-19-2002 10:58 AM
quick newbie question bojangs Bit Char-G / MicroSizers 2 10-06-2002 12:44 AM
newbie question ViperKid Bit Char-G / MicroSizers 1 05-28-2002 08:15 PM
