Old 12-27-2004, 06:29 AM
Maarbjerg Maarbjerg is offline
Dual Cell Help!!
I have made a dual cell, but there are some problems. I charge it for two (sometimes more) minutes. But it will only drive for 5-10 secunds. Do I use to large wire or what??
Ready... set... GO... :P
Old 01-05-2005, 10:54 AM
nasphere nasphere is offline
BitPimp
you do realize that a single cell is 1.2V, and a dual cell is according (2.4V). that means the charger on the controller is only capeable of charging one battery. a seperate charger is needed.
heres a link to a thread that you need, look at the bottom, it explains what you need.
Whack!
Old 01-09-2005, 06:59 AM
hmm well I followed this guide http://www.tinyrc.com/qfm/racing/mod_07.htm#26 sholdn't that work??
Old 01-09-2005, 07:33 AM
mshkttck's Avatar
mshkttck mshkttck is offline
I don't know what's wrong with that, but you may be able to use a charger made for 2.4V. A Zipzap monster truck controller should fit it if you hold the bit down with a rubber band.
Also, one of the batteries may be dead or damaged from the soldering, or the PCB may be fried.
Old 01-19-2005, 10:16 AM
Matic Matic is offline
Are you sure that you put insulator beetween battery and terminal ? If you didn`t, one of your battery is short-circued ....
Laymans dual cell vs. traditional dual cell Zephyranthes Bit Char-G Mods and Projects 6 02-18-2003 06:12 PM
Dual cell mod and discharge problem (cell reversal). kenny_dilger Bit Char-G / MicroSizers 1 12-17-2002 10:23 PM
