Old 01-19-2005, 10:18 PM
rs2000's Avatar
rs2000 rs2000 is offline
Xmodder
Send a message via AIM to rs2000 Send a message via Yahoo to rs2000
Gears grind often.
Hmm, I was driving across my water bed because I was bored, and the car bottomed out for a sec, where all four tires were of the ground, and it rocked to one side so both tires caught. When it hit i heard a grind and the car did a flip, ever since then the gears grind a lot, how could I fix this?
*Nissan 350z*
[COLOR=royal blue]
-Stage 2 red SB hybrid motor (soon to be neo mags, BB can and BB endbell)
-IC-3 800 mAH bats - 4 cell
-AWD
-Blue springs up front, silver in back
-Aluminum locknuts at all four corners
-Locked rear diff for drift action!
[/color]
Old 01-20-2005, 12:57 AM
newbitowner's Avatar
try screw the motor mount tighter
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 01-20-2005, 10:14 PM
rs2000's Avatar
Xmodder
everything is on tight, its the diff gear and the colored gear that came with the motor.
*Nissan 350z*
[COLOR=royal blue]
-AWD
[/color]
Old 01-20-2005, 10:19 PM
Pocket_Rocket's Avatar
Pocket_Rocket Pocket_Rocket is offline
Try shifting the weight towards the back of the motor, so the brass pinion is up from the plastic gear, that should relieve some stress. And if that doesnt work then I would remove the Motor mount that is located in the back and play around with the motor until you stop hearing the grinding noise.
-Ryan
"Theres no Shame in my Game!"
Old 01-22-2005, 03:16 PM
Loganberry Loganberry is offline
yeah the same thing is happening to me. the bevel and the differential grind cause the differential is slidding on the axle. i think im taking it back cause theres some other problems with my xmod. fun while it lasted. later
xmod:acura nsx
zzmt:bigfoot - motors and tires
Pinon gears. dje7447 Bit Char-G / MicroSizers 7 10-09-2003 03:52 PM
Tips for quieting gears NoPropMan Bit Char-G / MicroSizers 14 03-27-2003 11:59 PM
K.I.T. gears = stupid Zephyranthes Bit Char-G / MicroSizers 4 03-14-2003 12:59 AM
clone gears vs bit gears ? Mike the Great Bit Char-G Parts and Hop-Ups 10 01-19-2003 01:05 AM
loud gears?? streetrage Bit Char-G / MicroSizers 6 12-16-2002 11:11 AM
