Old 08-10-2004, 07:38 PM
skunk'd skunk'd is offline
drifting
i am thinking of buying the bitchg auto modellista set and also these parts.
3.8 motor
tyre set
suspension set
nimh bat
but with the suspension set you get drift axles i was just wondering are the axles any good and will they be good with the auto m set
Old 08-10-2004, 07:44 PM
Jtskty Jtskty is offline
Master Debater
Send a message via AIM to Jtskty
The drift axles are really not that good. I would just get a regular set or maybe a pro set not auto modelista. Save the extra money for parts. I would definately get springs. Get as many different tires as you can. Make sure you get a gear set. Also, I would get probably about 3 different motors to see which ones give you the best feel. Remember it is not also the fastest. Also, if you are going to be getting a 2 speed car I think torque is the most important. About the battery, I wouldn't worry about that either. Oh, one last thing, most people say you can't do a real drift in these cars.
Old 08-10-2004, 08:00 PM
i got springs
i can get the auto modellista set for aus$60 which is like $45 american
and nimh batteries any good or do they wreck the car
Old 09-17-2004, 08:18 PM
JDM-R34 JDM-R34 is offline
Send a message via AIM to JDM-R34
nimh batteries are great at least the 200Mah ones are good, I got those in my bits, oh and where do Ya'll get drift axle's and suspension/springs from? Thanks,
Oh You really can't drift in the cars because in real cars motors are in the front, then in the back there are limited slip diff's, so idk it might work some what.
Old 11-17-2004, 08:18 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
You can do real drifts in these. They are real wheel drive and I do drifts all the time.
My setup:
Hard front MS tires
Soft rear MS tires (if you have too much rear slide use mediums instead)
9.86:1 gearing (orange)
3.0 motor
MS Pro chassis or regular Bit Char-G chassis
It works great. If I use the Pro I pretty much need to use the mediums in the rear but with regular you need the softs. (I am not sure if this setup works with Bit tires. I have only used the MS tires)
Good luck and have fun.
Old 11-21-2004, 02:39 PM
skyline7 skyline7 is offline
Flip the body around and u can drift
Super Slicks WRC WRX
Hard tires
Blue motor and Gearing
Stretched antenna for
better range
Old 11-21-2004, 03:33 PM
MattPaintballer's Avatar
MattPaintballer MattPaintballer is offline
iPod therefore iAm
I think he wants to "really" drift rather than go SuperSlicks style...
Old 11-22-2004, 11:07 AM
nasphere nasphere is offline
BitPimp
me and frizzen were just talking about going 4wd... the hardest parts are the steering has to be flipped, and it needs like mini half dog bones for the front drive... the rest i think is easy! but 4wd would be a sweet drifter, put hards on all fours, and go driftin... and never spin!!
Whack!
Old 11-30-2004, 02:13 PM
micro-rc-guy's Avatar
micro-rc-guy micro-rc-guy is offline
Well if u do go 4wd,
Id be happy to pay you to make me a 4wd bit.serious man that would be wicked 4wd no spinning out, considerably faster , better handling, Ooohh the possibilities
Old 11-30-2004, 03:48 PM
Racer9's Avatar
Tiny RC Pro
that idea is almost as non sensible as my rotary idea. It is cool but it would be insanely hard and wouldn't really be that beneficial unless you drive on really dusty surfaces.
Old 12-02-2004, 05:43 PM
BitPimp
the only thing i think might be hard is the half shaft cv set up, aside from that a new chassis needs to be constructed, new steering set up, everything else is a breeze. im not saying im gonna do it any time soon, i have enough projects going, one of which has got me away from bits for a while, never woulda thought... but coil guns are just so fun!!
Whack!
A simple guide to drifting (WIP) micro-rc-guy XMODS 0 02-06-2007 04:20 AM
Drifting iphong XMODS Gallery 11 01-03-2007 09:40 PM
Drifting an Xmod rody XMODS 1 01-01-2007 09:25 PM
duall cells for drifting boho Bit Char-G / MicroSizers 10 07-14-2003 08:37 AM
