12-09-2004, 11:05 PM
Xmodder
SB mod
Just got done with my spinbrush mod, though I dont have a working car (  ). But it seems to go much faster! The old magnets are about 3 times weaker than the spinbrush ones, which seem to be pretty promising (it better be! I screwed up a stage 1 blue, and a stage 2 yellow making it  ) So now i have 2 extra sets of weak magnets and clips (if you need them, you can have them). How much does this mod help out? I can't wait to try it out!!!
*Nissan 350z*[COLOR=royal blue]
-IC-3 800 mAH bats - 4 cell
-AWD
-Locked rear diff for drift action![/color]
12-09-2004, 11:13 PM
Xmodder
Woah, did you guys just see that xmod comercial on comedy central? SWEET!!!!! What irony...
-AWD
12-10-2004, 05:02 PM
Xmodder
Ok, took another SB motor, put an xmod cap on the end, drilled a hole in the top, and replaced the armature with one from some toy that i modded and had lying around, this thing can SPIN!! (if you drill a hole in the top of a motor, make sure you file out the hole, i had problems with metal scraping the armature (the sb one) which is ruined now). Just need a pinion for it.
EDIT: oh yeah! forgot to ask, are neo mags better than SB mags?
-AWD
12-10-2004, 10:20 PM
Happiness is a warm gun..
They accelerate and stop much better, I have a red stage 2 with sb mags and it flys. I believe the neo mags are more powerful.
Make sure you break in the motor before you put it in
12-10-2004, 11:17 PM
Xmodder
Umm, never broke one in before, but the sb motor was used. How do i break it in, and what will happen if i dont?
EDIT: Ok, i dipped the motor which i drilled first to break it in, and it cleaned it out ( there were tiny metal bits all over the sides of the glass, which i thought i had gotten out) and lubed it with a tiny bit of grease from the AWD kit ( I wonder when it will catch fire) and it seemed to help it significantly. Performed this on my red stage 2 with SB magnets and it no longer "chattered" when at full throttle which it did before. No way to check speed or anything untill i get a car  . Oh, and I plan to buy a BB endbell, a BB case, and neomags for my motor. What are some good brushes for it and where can i find them? Pretty soon i'll be winding my own and ready for the track.
-AWD
