Old 09-08-2005, 12:39 AM
blind's Avatar
blind blind is offline
None Better
750mAH AA sized Lithium battery kit
I have 6 sets for sale, all are made with the best you can get 750mah Lithium batteries.
2 cells, 7.2v of power. Each set comes with the cells built into a pack, the cells dipped in a clear extremely thin waterproof rubberized coating that waterproof's and protects the pack from ground scratches. Each pack has a mini plug connector on it, and a mating plug with a few inches of wire is included that is ready to solder to your cars existing wiring (or replace the existing wiring and soldered into the PCB board.
The kits include:
2 lithium cells built into a pack, ready to drop in
4 zip ties
mating connector for xmod
Total price with priority shipping included is $20
I can also sell chargers as an option for an additional $25.
Old 09-14-2005, 10:40 PM
blind's Avatar
None Better
installation is very simple and can be done by a novice in under an hour.
-EP package and motor needs to be removed
-remove, then cut wiring off the stock battery trays
-4 small holes need to be drilled or reamed into sides of chassis
-trim the battery tray rails to be flush with sides of chassis
-strip factory battery wires and solder on new male connector
-ziptie the cells to the chassis sides
-plug in and go!
CJ's Xmods FAQ (Updated June 27th.) cj1267 XMODS 64 05-30-2007 07:43 PM
BC-G Battery vs. KIT Battery datamonster Bit Char-G / MicroSizers 1 11-12-2002 05:19 PM
How long will a 3V Lithium Camera Battery Last ??? shred Bit Char-G / MicroSizers 0 10-18-2002 01:41 PM
