Go Back   TinyRC.com > 1/24 and Smaller > ABC DTM > ABC DTM X4
Old 09-28-2004, 01:12 PM
Truth Truth is offline
Runtime with a 7.2v and 180 motor? Anyone else use this setup?
Hello, I just built a pack using 2/3 AAA batteries, 300 mah. 7.2 volts, its very fast but I only get about 2 mins. on a full charge.
Old 10-08-2004, 10:52 PM
Hardtrukr's Avatar
Hardtrukr Hardtrukr is offline
I'm The Youngin' of R/C
Send a message via AIM to Hardtrukr
Two minutes?! I'm running a 7.2v 300mah pack (2/3 aaa's) and get nearly 15 with my 45T Micro Mod motor.
Hey Officer, Did You Stop At The Donut Shop On The Way Here?
Old 10-21-2004, 03:25 AM
pixelator
I was getting what seemed horrid times with the optional ABC 300mAh battery and later discovered a couple of things: 1). My Novak SPY was fried and 2). There was way too much friction in my drivetrain (both ball diffs needed loosening, and the pinion was meshing too tightly with the spur).
After loosening everything up and installing bearings, I get much better times (as well as having a new ESC).
