Could someone provide me a list of compatible bodies
for the M03L?
i believe it is either 239mm or 225mm wheelbase...i've seen
different specs from different sources...
basically, any idea if a 225mm wheelbase body will fit
on the M03L?
i have no idea how long the m03L is. but the M01 and m02 L do not fit the 225 mm bodies. so if its the same, then it shouldnt fit. the 225 mm bodies are the m01M and m02M chassis. hope that helps.
The standard wheelbases for mini bodies from Tamiya and hpi are
Std(ie M-03, m-02 m-01): 210 mm
M(M-02m, M-03 with RCBOyZ extension): 225mm
L(M-04L, M-03L):239mm
-Anthony
