Old 03-18-2004, 07:01 PM
97supra97 97supra97 is offline
motors wired in reverse some one plz look
hey guys.... one thing ive noticed with these cars are that the motors are wired in backwards....so if you buy an after market motor such as the hpi micro motor you would have to put the positive led to the negative on the motor...no running the motor in reverse is actually slower than if you wired the motor in positive to positive, get my drift? but if you would do that the xmod will run in reverse instead of going foward >.< it sucks cause i have a plasma dash motor and having it wired in backwards is slower than when i wire it correctly...positive to positive.... ok the point is...do you think wiring the motor clock-wise would fix the problem? plz help
Old 03-18-2004, 07:05 PM
SHIFT_DRIFT's Avatar
5Zigen
just switch the two wires or reverse the magnets.
Try And Sleep Now.
DRIFT my ANTI-rice
Old 03-18-2004, 09:07 PM
R33E8 R33E8 is offline
or you can try flipping the motor upside down...
Xmods Civic:
Old 03-19-2004, 11:27 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
reverse the magnets. just pull the endbell off and the little spring that holds them in and switch them. them put it all back together.
NEVER UNDERESTIMATE THE POWER
Old 03-19-2004, 03:06 PM
but
so switching the position of the magnets will fix this problem...?
what about those 180 motors that cant be opened example ff-180ph?
Old 03-19-2004, 04:37 PM
Just switch the wires...
Xmods Civic:
Old 03-19-2004, 07:01 PM
okay, first of all...switching wires isnt the same as if you wired positive to negative cause the motor runs slower in reverse...so you posting swith the wires is a waiste of my time...did you read the first post i did up at the top?
Old 03-19-2004, 08:48 PM
aperson's Avatar
can you post a pic of the bell that cant be removed?
motors and pinions? sawhit4 Bit Char-G / MicroSizers 0 06-04-2005 05:43 PM
Making motors faster. moebrown20 XMODS Mods and Projects 0 10-15-2004 03:01 PM
Xmods Video MicroRCEngineering XMODS 10 01-24-2004 11:39 AM
Plz Help B4 I Go Crazy!!!!! Calsonic_racer Bit Char-G / MicroSizers 2 04-20-2003 01:36 AM
bit motors...ZZ motors....DKS motors tarnjit ZipZaps 1 12-06-2002 05:06 PM
