Old 02-27-2004, 01:25 PM
dolfan03 dolfan03 is offline
replacing screws and antenas?
anyone know what screws to get to replace the stock ones? what about useing a standard 1/10 scale antenna?
Old 02-27-2004, 07:33 PM
RC 2NR RC 2NR is offline
TinyRC XModder
You can special order them through RS. Check CJ's FAQ.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-27-2004, 11:54 PM
newbitowner's Avatar
a lot of parts are on backorder and you won't get them soon or at all
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 02-28-2004, 08:33 AM
TinyRC XModder
I'd bet screws aren't on backorder..they might be, just call them.
You could just go to a hardware store and see if you can find any screws that are the right size.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-28-2004, 12:41 PM
codedat
I tried the hardware store bit. Nada found, close but not the same size. You are better off at your local hobby store.
Old 02-28-2004, 01:36 PM
ok, thanks guys i"ll check around some more and let u know what i find .
Which lower deck screws do you use for AWD kit? newbitowner XMODS Parts and Hop-Ups 5 01-31-2004 01:05 PM
screw screws!!!! shane-o XMODS Parts and Hop-Ups 14 01-05-2004 09:19 AM
60 Second motor swap w/ stage 2 (5 screws!) ax0n XMODS Parts and Hop-Ups 2 12-30-2003 12:59 PM
XMODS Screws cloned each other QPizzle XMODS Parts and Hop-Ups 1 12-29-2003 03:22 PM
replacing resistors jamgunner Bit Char-G Mods and Projects 0 07-06-2003 09:31 PM
