02-06-2004, 12:05 PM
Using non logic level fets WITH a regulator
Hey, decided i'd let the cat out of the bag and show a circuit i've been fooling around with for a while. this circuit allows you to use non logi level fets for the xmods raido board, might solve a lot of problems as finding compontents goes.The diodes are zener diodes, they'll conduct reverse voiltage @ 3.9v or whatever voltage you'd like, so 3.5v is seen as zero at the mosfet gates and only the 5v gets thru, perfect for most fets that require a difference of 5v to switch on. You can also use transistors to drive the mosfets instead of the zener diodes, U just thought this be easier  BTW i don't have two sources, i just did that to simply the diagram, peace
02-06-2004, 01:23 PM
I'll have to look, but I think regardless of whether or not you use logic level transistors, the IRF4905 is the best P Channel FET out there. And it is that FET that is on backorder.
02-06-2004, 05:44 PM
That's very true, considering the on resistance and other specs of the irf4905, but this circuit was designed if you couldn't use the irf4905( because of the popularity ) or wanted to try out some fets that are just sitting around without making a serious investment in time or money(more time in the fact that you'll have to wait for a shipment of irf4905 to come in AND then wait for it to arrive at your house ). Plus, i thought that it might help in designing a h-bridge circuit for yourself, i mean 4 zener diodes as opposed to waiting for several months isn't a bad preposition.
02-06-2004, 06:01 PM
BTW the way , this circuit is the basis of an h-bridge AND a regulator for the radio, so check it out
