Old 12-17-2003, 03:19 PM
Speedycheater
One Heck of a Controller Mod coming up!
I'm currently workign on a design for a controller mod that I will be doing over the next 3-5 weeks. It will feature a seperate box with plugs for power, PC, 2x Joystick/Game pad. It will feature computer control (if I can get a copy of the software), with basically an integrated Nox Box. It will feature two 9 pin, or 15 pin game ports for a joystick or gamepad and A built in peak charger with charging base, switchable between single or dual cell. It MAY also have switchable frequencies, but that is only an idea right now, and may not be integrated into the first design. Any ideas on anything else to add to this? Also, does anybody have a copy of NOX's software trial or full version I can use?
Old 12-17-2003, 03:24 PM
charliebrown's Avatar
As soon as you put up the tutorial and pictures, I'm smelling Namuna moving this to Bit Science! Good luck on the project!
Old 12-17-2003, 03:36 PM
Speedycheater
Thanks! I'm still in the process of designing it and collecting parts, so it will still be at least a few weeks. I have a question though: Will charging the 150 mAh batteries at 2.8VDC 350 mA work for single cell and charging at 5.6VDC 350 mA for dual cell work? I'm basically using the electronics out of a Sunpak AA/AAA NICD/NIMH peak charger for the charger.
Old 12-17-2003, 03:57 PM
For charging questions, http://www.tinyrc.com/forums/showthr...?threadid=6045
read Namuna's posts near the bottom of the page.
Old 12-31-2003, 08:59 AM
Speedycheater
Well, if this mod is going to happen, I need a copy of Nox's software. Does anybody have one?
Old 02-18-2004, 04:29 PM
Speedycheater
Well, This mod is pretty much on hold becuase Nox for some reason removed his software and will not let anybody else use it.
controller mod natedogg4674 ZipZaps 2 01-10-2003 12:27 PM
controller mod natedogg4674 Bit Char-G / MicroSizers 4 10-29-2002 02:49 AM
controller mod & solution for poor range natedogg4674 ZipZaps 4 10-13-2002 09:40 PM
cheap zz controller joystick mod lnx_author ZipZaps 12 10-13-2002 12:21 PM
