Old 02-01-2004, 01:03 PM
hostyle hostyle is offline
Magnets
Does it hurt a magnet to shave it a bit to fit a can? I was going to do the SB mod but then saw a brush that had a Braun motor and figured it had to be better than the crest motor. Unfortunately the Braun can is longer and so the magnets are longer. The RS armiture is too short for the Braun can and the Braun magnets are too long for the SB can. I was planning on shaving the Braun magnets to fit in the RS motor, will this hurt the magnets?
Old 02-01-2004, 10:54 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
i think the Braun motors are 180 type motors, if they have the same shape as teh xmod motors but just a little longer, then their 180 motors and if you have one of the xmods that uses the longest wheelbase, you should be able to fit it in. just solder the connector and caps from an old xmod motor to it
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 02-02-2004, 03:06 PM
RC 2NR RC 2NR is offline
TinyRC XModder
Don't just assume that the magnets are stronger. And yeah, TypeZer0 is right, the 180's will fit in the Skyline and Supra.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-02-2004, 04:33 PM
Silent_NightR34's Avatar
Got Mini-z?
and civic...
Old 02-02-2004, 11:32 PM
Im not assuming the magnets are stronger. They are stronger, you can tell by their pull.
Old 02-03-2004, 08:11 PM
TinyRC XModder
Ok, then use the Braun can, magnets, and armature, an RS endbell and brushes (and pinion, of course).
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Motor Efficiency Mod LBRC Epoch RC1/43 Parts and Hop-Ups 0 01-26-2005 02:42 AM
Spinbrush magnets (courtesy of xmod forums) cdog4w Mini-X Parts and Hop-Ups 2 02-28-2004 10:34 AM
Used SB magnets...going backwards? Exaran XMODS Mods and Projects 2 01-16-2004 07:54 AM
Neodymium magnets? bluemax_1 Mini-X 1 03-29-2003 12:36 AM
Rare Earth Magnets..... DarkTari Bit Char-G / MicroSizers 5 03-09-2003 06:32 PM
