Old 01-18-2004, 01:07 PM
newbitowner's Avatar
The Tamiya Mini speed checker said 39kph(24mph).
Are the Xmods the same size as Tamiya mini 4WD cars?
If so I can go 24mph!
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 01-18-2004, 01:30 PM
For everyone who has a speed checker time your 100m times.
I'll do mine when the AAA are ready.
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 01-18-2004, 04:07 PM
German fellow's car at XModRC, not mine.
Old 01-18-2004, 06:05 PM
demon's Avatar
demon demon is offline
heres my km/h,it did 1.09 in 10m
Old 01-18-2004, 08:31 PM
RC 2NR RC 2NR is offline
TinyRC XModder
The most accurate way would be to check it with a radar gun.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 01-19-2004, 12:19 AM
Railside270's Avatar
Railside270 Railside270 is offline
Topsoul to 540 out
Send a message via AIM to Railside270
Are you guys using 5 or 6 cells? I was wondering how fast a 5 cell would be because i might add one to my car.
RCtunerzforum.tk
Your source for micro RC tuning!
Back Up My Hard Drive? How do I Put it in Reverse?
Old 01-19-2004, 01:13 AM
I use 6 AAA I-C3's and hit 40km/h with the blue motor.
It did the 10m in 1.03?
You roll then hit the start button, right? I think the front wheel drivetrain is what's slowing you down.
Or do you hit the throttle all the way on the third beep?
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 01-19-2004, 01:14 AM
It did 9.93 in 100m.
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 01-19-2004, 09:08 AM
neurokinetik's Avatar
Keep in mind that this checker is made for cars that do not have throttle control. You are supposed to set the car on it, get the wheels spinning slowly to make sure it is going straight, then you go wide-open, and then you hit the start button and take your measurement. When you do the time-to-distance measurement, you are supposed to be full throttle before you start.
For the most accurate results, you should be running the car with the body on (not possible with all bodies, as the front overhang is too long), and all four wheels should be turning the rollers (unless of course, you are RWD)
My drag Civic hits 38kph on my speed checker with six cells, and 33kph with four cells.
I don't think you can correlate results from machine to machine, though. It's more for testing your gains/losses.
Old 01-19-2004, 02:09 PM
I agree.
I just wanted to see a rough estimate of where my car ranks.
With the power from 6 cells I have a lot of trouble keeping the car on all 4 tires.
Would the susp. upgrade help a lot?
How should I setup my suspension so it wouldn't be so easy to flip over?
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 01-19-2004, 02:30 PM
2fast4u 2fast4u is offline
Send a message via AIM to 2fast4u
possibly the best setup is medium all around if u are a perfectionist like me you spend at least 4-5 hours evening out the suspension balancing the springs and checking if the tires are parallel to the ground so far on my car is flips less gets more grip
turns better and accelerates faster with yellow definatley for the rear but i have not yet tested and balanced the front
mini z:ferrari f-40
xmod:body undecided
Old 01-19-2004, 08:15 PM
demon's Avatar
whats the sense in being full throttle when your doing a time/distance run?when u put the car on u can give it gas then let off,then the car will stop blinking,then u can push start,if i have mine full throttle on the 10m,it does less than a second.that doesnt give me any idea on tq
Old 01-20-2004, 10:15 AM
These things just aren't designed to do that kind of measurement. If you could start from a dead stop, then it might mean something, but the speed checker is designed only for top speed. That's it.
Honestly, I don't know how useful the time/distance run actually is, even for the Mini 4WD guys that this was designed for.
Old 01-20-2004, 02:59 PM
It's hard to compare if we don't have the car WOT for distance runs.
I had my car go 45km/h!
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 01-20-2004, 03:55 PM
demon's Avatar
thats what i tried to explain,u can start from a dead stop
speed checker zpzps ZipZaps SE 0 01-19-2006 05:25 PM
Do you have a speed Tamiya checker? post a VID!!!!! newbitowner XMODS Mods and Projects 0 08-25-2004 08:37 PM
Tamiya Speed Checker with Xmod 93Supra0wner XMODS 0 01-05-2004 06:59 PM
tamaya speed checker boostmonger XMODS 10 12-21-2003 09:27 PM
