01-14-2004, 07:48 PM
i wish my xmod could do mad donuts like that!
here in akron ohio its snowin like mad. after jazz band today at about 8 ,my friend took me to go do donuts in his v8 gmc sierra. after we unloaded the bed so there would be no weight we went mad. Wuts a good way to get my RWD skyline to do supermad donuts? i know about using scotch tape but i need sum really grippy front tires otherwise all i get is half donuts. any suggestions
xmod blue civic ricemobile.
01-14-2004, 08:07 PM
Grippy front tires?
If your racing on hard, smooth, flat floors, like indoor tiles or hardwood, then use the soft tread tires, found in the rubber tire uprgade kit. Make sur your floor is clean, and here's a quick solution:
take the tires off the wheels and get a bowl of hot water. Let your tires sit in the water for about 30 seconds, then take em out and dry them in a paper towel or regular towel, whatever. Bow drying is not recommended
put them back on, and see how they run. From the hot water, they should be a little softer and give you a grip on the road.
If you're going on the flat concrete, on the tennis court, or outdoors, go for the hard tires. Good luck!
Chuckster...
01-14-2004, 09:00 PM
Confirmed: Lost In Fog
your in jazz band too??? i play piano in my high schools jazz band
in down here in oxford near cinci........mind send a bit of you snow to us? all we have is rain and ice......
-Andres
01-15-2004, 12:21 AM
boro dori style RC
scotch tape is a good idea. also you should try locking ur diff or just converting it into an lsd then you can pull off doughnuts like nothing. and stick with drift gears.
r34 - rwd
r34 - awd
dd4 - fwd
01-15-2004, 12:46 PM
i just got a sno day upin ny..... try a vinyl floor like in ur kitchen or sumthin and rty puttin no tire on the rear, or wrappin the tire in a rubberband, andthen scotch tape, so it will be like ( = )instead of | = | so theres less to touvh the ground ^^^ view from tpof tire
01-15-2004, 04:40 PM
well i got my car to do crazy donuts and spinouts. i masking taped the rear wheels and cleaned off the front wheels with a damp cloth. it was awesome
01-15-2004, 04:54 PM
0reZepyT
try the foam tires in the rear
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
01-15-2004, 05:11 PM
You mean like this? This car is AWD with soft rubber slicks. The key here is excessive power to the wheels, and a fairly slick surface.
http://users.adelphia.net/~neurokinetik/ras.avi
01-15-2004, 05:33 PM
0reZepyT
lol, omg, that's nuts haha have you tried gunning it straight for like 20 feet than turning hard and make it spin like crazy?
01-16-2004, 09:30 AM
that vid didn't work for me
01-16-2004, 11:32 AM
01-16-2004, 02:59 PM
im capital 1"s CE NO!!!
I have a tile floor so if I just put a little bit of water onthe floor I can do insane donuts.
if you have ever stared into a can of
orange juice because it said concentrate you might be a redneck...
01-16-2004, 03:48 PM
neurokinetik....thats some crazy stuff there on ur video.....is that a gym floor?
01-16-2004, 06:00 PM
Nope, it's a roller rink. I've got more footage, but I need to finish my other video before I can start editing down that stuff.
01-16-2004, 07:57 PM
k
post the longer vid here when its done....cant wait to see it
