01-17-2004, 10:09 PM
Type-R
Question
Would a 5th cell mod fry a stage two motor? Or is it the same as with 4 cells?
My XMOD:
Acura Integra Type-R
180 Motor with Drag Pinion
6-Cell Upgrade
FWD
Locked LSD
Hard Springs Front and Back
Soft Slicks in Front
Hard Slicks in Back
01-17-2004, 10:17 PM
"Its OK I had subway"
NO i dont think so unless u run it that long anywayz 5 cell only makes a longer run time
01-18-2004, 12:33 AM
No, it adds more power.
Xmods Civic:
01-19-2004, 08:13 PM
i believe that a 5th cell adds runtime and 6 cells add power
01-19-2004, 09:19 PM
LOL
If you want to add run time, you wire the extra battery up one way. If you want to add power, you wire the battery up differently.
Thats the difference between running the batteries in a parralel or a series.
The extra 1.2-2.4v won't fry your motor. The motor itself can handle quite a bit of voltage(more than 12v).
01-20-2004, 09:09 AM
thats right the motor can handle more than 18 volts but the electronics are the problem. without some serious modding or replacement w/ stronger electronics they wont take more than 9 volts.
01-20-2004, 10:31 AM
Quite a few people, and I have no reason to not trust it, consider 8.4v the max that the stock ESC can take without damage - atleast for extended periods of time.
