01-12-2004, 08:29 PM
How to upgrade motor wires using stock connectors
01-12-2004, 08:30 PM
There is two grooves in the holes with the male pin
01-12-2004, 08:35 PM
What yoy need to do next is find something small to fit into grooves with the male pines(I used the metal spring thing that holds the magnet in place inside the motor).
01-12-2004, 08:42 PM
The odject is to get something in there to press the Tiny tabs down on the male pins .doing this will allow you to pull the wires out the housing
01-12-2004, 08:47 PM
Once you get wire out pry open the clips that holds the insulated part of the wire. pull the wire out of the clips and cut wire
01-12-2004, 08:50 PM
prepare new wires. place wire in male connector. close clips then solder
01-12-2004, 08:56 PM
Remember to pull the Tiny tabs back up so the pin can lock once its back in and also when placing the pin back in the housing the pin goes in where the tabs sticks upward and the groove in the housing fits.
01-12-2004, 09:07 PM
Car female connector . On the female housing press the Tiny tabs down and pull the wire out the housing.Repeat male connector procedure for installing wire and placing back in housing
Note: Mark pos+ and neg- on housing so you know where wires go. Need any more details let me know.
01-13-2004, 10:47 AM
Nice work jon.jon. I'm gonna make a link to this in the Tips and Mods sticky.
01-13-2004, 01:44 PM
I was hoping it would be helpful information. Thanks.
