Old 01-01-2004, 05:38 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
Important! Please Read!
I was playing with my xmod when it started to smoke. then, the range went down to like 4 feet. will RS take it back for a new one? if not, how can i fix this?
Old 01-01-2004, 07:59 PM
WhiteSupra43 WhiteSupra43 is offline
"Umm I need a new car"
Send a message via AIM to WhiteSupra43 Send a message via Yahoo to WhiteSupra43
put it back in the box and take it back with the reciept and tell them wat happened then they wuld mess around with it they shuld give u another one
Old 01-01-2004, 08:34 PM
Joey's Avatar
Joey Joey is offline
Given that you haven't modified it visually. Then they're not going to do much about it, but you can usually get them to take stuff back that's even been played with on the inside.
Your problem sounds like total equipment failure though, and not your own, so you shouldn't have a problem.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-02-2004, 09:12 AM
the only thing i did t the inside was bearings and steering rods. some of the screws are stripped, will that matter?
Old 01-02-2004, 09:35 AM
Bad Company's Avatar
No, but you may want to reinstall the stock parts so you can put the bearings, etc. on your new car.
Old 01-02-2004, 10:44 AM
neurokinetik's Avatar
I really want to learn what the cause of this problem is. It really can't be all that hard to fix.
Old 01-02-2004, 10:59 AM
that would suck if someone forgot to take the bearings out. 20 dollars down the drain. there is one problem though, i lost one of the suspension things. the black thing and the spring. i am hoping he/she want notice it but it they do just trade one from the new car.
Old 01-02-2004, 09:48 PM
everything is ok now. i exchange it for anew one and the guy didnt even look into the box.
Old 01-02-2004, 10:53 PM
Rx7NoZ's Avatar
Rx7NoZ Rx7NoZ is offline
take it back with the reciept make sure u still have everything in the box though
Xmod:
Civic (black)
Stiff Suspension
Awd
White side skirts,White Carbon fiber hood,White rims and Drop
Old 01-03-2004, 07:43 AM
byebye's Avatar
byebye byebye is offline
What you probably did is shorted out the antenna to the batt leads or the motor leads. I did it twice with a plume of s Both cars had mods also and I had to take them off before I took it back. They should take it back and tell them what happened. Also, if you take out the batts and the rx crystal and disconnect the antenna from the lead you have less of a chance of shorting it out. If x-mods didn't have so many parts things like that would happen less. If you have money like "BC" and can buy several x-mods then you can setup cars for different conditions eliminating all the constant changing of parts.
Old 01-03-2004, 10:36 AM
thanks for the info but i already took it back. the guy didnt even check to make sure everything was there! HAHAHA
Old 01-03-2004, 10:48 AM
security civic security civic is offline
sleeper mall civic
Send a message via AIM to security civic
look at my thread civic on fire then u will c a link or anothere thread that will tell u what happend cause the samething happend to me but i forgot what they were called
douglascounty!!!
Old 01-03-2004, 10:56 AM
thanks. is that in the XMOD forum? not parts and hopups and those?
Old 01-03-2004, 10:57 AM
sleeper mall civic
xmod
douglascounty!!!
Old 01-03-2004, 07:07 PM
aperson's Avatar
aperson aperson is offline
do a search for my thread called "Extended Range?" for a fix.
extra cell skeptics....READ READ!!!! lemans23 XMODS Mods and Projects 24 12-30-2003 01:09 PM
Modifications? RSXRacer001 XMODS 10 11-25-2003 07:18 PM
Important Update. Read this. spike_101 For Sale/Trade 1 11-04-2003 05:09 AM
Important question Colt45101st Auldey (All) 2 12-27-2002 07:17 PM
read japeneze Bit Char Bloke Bit Char-G / MicroSizers 20 11-17-2002 07:47 AM
