Old 12-27-2003, 11:52 PM
christhn christhn is offline
problem with controller
I wanted to remove the steering wheel to make the controller have left handed steering. However, for some reason the screw would not come out and now it's worn out. The screw driver will no longer grip it. Does anyone have any suggestions?
Old 12-28-2003, 12:22 AM
wasuri's Avatar
wasuri wasuri is offline
Send a message via AIM to wasuri Send a message via Yahoo to wasuri
Either get a larger screw driver and push really hard....lol it always works for me or get a small dremel drill bit and drill it out then use a xmods screw witha small washer on it to compensate for the lost screw.
Old 12-28-2003, 12:31 AM
pbmax's Avatar
pbmax pbmax is offline
Li-Ion Addict
Yeah, do yourself a favor and buy some hardened-tip screwdrivers, and always use the right size (biggest possible one that doesn't slip). Haveing used crappy tools for years, I've found that good ones make all the difference
pbmax
Old 12-28-2003, 12:56 AM
I had actually tried the larger screwdriver idea before I posted here, but it didn't work at the time because the screwdriver kept slipping. After reading the responses I got here, it finally occurred to me that I should actually wear out the screw even more so that a bigger screwdriver would fit. Everything works now! Thanks guys!
Old 12-28-2003, 09:21 PM
wasuri's Avatar
Np. Glad to help. If I did at all, that is. lol
Controller trouble... Sleeping911 ZipZaps 0 06-24-2004 11:33 PM
New controller id problem! spad Combat Digi Q 2 02-27-2004 02:55 PM
controller problem chibi-sephiroth Bit Char-G Parts and Hop-Ups 0 11-06-2002 12:11 AM
