12-20-2003, 01:18 PM
do u need to use capacitators on a spinbrush motor?
do u really need to use capacitators on a spinbrush motor?
12-20-2003, 01:38 PM
XMOD AUDI TT (my wish)
yes, they keep the esc from getting fried during braking, when the motor is actually creating power, they also cancel some sort of frequency the motor gives out during operation that can interfere with the controller/pcb of the car.
if u dont get it tell me and ill see if i can state it more clearly
12-20-2003, 02:37 PM
1 i dont get it and 2 would u need them on a spinbrush motor
12-20-2003, 03:52 PM
heeelp
12-20-2003, 05:50 PM
I Shall Return!
ok well first of all you asked this is your thread (which is a ripoff to mine... no hard feelings) and also its been answered like 10 times...
second theres nothing not to get any motor (including the presious spinbursh needs a capaictor, fyi a capacito is the lil tan circle thing on the wiring of the motor) if you dont use a capacito your receiver wont respond when you use you controller, and if it miracurously dose , the motor will explode (when you are moving foward and hit reverse, current passes in the opposite direction and so you motor will explode) so to answer you question, yes you do, even on a spin brush and on any motor that will ever be created...
12-20-2003, 06:57 PM
wut about the black thing
12-20-2003, 09:57 PM
I Shall Return!
i know what your thinking (ive thought it too) neither of the two thingys soldered to the motor limit its power or slow it down, by taking either one of the thingys off you'll simply hurt your motor
12-21-2003, 08:25 AM
do they haf 2 be soldered 2the side of the motor
12-22-2003, 11:32 PM
huh
12-23-2003, 12:13 AM
Yes. You have to solder them onto the side of the motor. It's pretty simple. Just solder it to mimic the RS motors. Or you can desolder the capacitors off of the stock RS motor sides and use the endbell from it onto the spinbrush motor. That way you eliminate extra soldering.
Jamie
