Old 12-04-2003, 07:32 PM
ruslick2g4 ruslick2g4 is offline
Unhappy skyline probs
lets cutt to the chase....my skyline makes these loud scratching noise and goes slower then my lil bros civic and rsx....my skyline is completely stock....u kno how would i b able to fix dis....and my lil bro's rsx steering messed up....when u trun it to go right it turns real slow or doesn't turn at all and it has alignment probs
Old 12-04-2003, 07:45 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
you might want to take the skyline back. but, when you drive it do you hit bumps or cracks in sidwalks or pavements? and withyou bros rsx, adjust the steering trim. that should help.
Old 12-05-2003, 10:02 PM
ummm....
well...its not a noise of of scratching on the floor....its like sounds like the gears or something...ok....but when u do dat on the control when u turn it off it just gets messed up again
Old 12-05-2003, 10:28 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
if you're pushing the button more that 30 times you gotta reset the servo by taking off the screw on the horn and turning on the car and controller and let the servo center then put the horn back on to where the bump lines up with the line on the servo case. i dont know what happend to the RSX but my servo turns faster one way than the other, im gonna clean it out and see if that helps if not return it or order a new servo. but if you get just a servo i think u gotta install it.
NEVER UNDERESTIMATE THE POWER
Old 12-06-2003, 08:50 AM
thankx
ok...r u supposed to put the screw on really tight cause when i try to screw it in i end up turnin the the white thing....and am i supposed to screw it in with the car and the control on?....did i mention that wit da rsx u could hear the steering motor then the whiles are straight
Old 12-06-2003, 01:04 PM
aperson's Avatar
put it on only as tight as it was on. and yes it will spin the horn, i forgot to tell you that you have to turn the car off
Old 12-06-2003, 03:15 PM
what is the horn? when i think of horn i think beep beep.
Old 12-06-2003, 03:27 PM
aperson's Avatar
the steering horn. the little white thing on the end of the servo that goes on the spline shaft.
Old 12-06-2003, 05:01 PM
ok thanks
Limited Edition Calsonic Skyline DigiQ and Pennzoil Skyline! r0dzill4 For Sale/Trade 0 04-15-2006 01:10 PM
AWD skyline but a few probs plz help 350z-zz XMODS Parts and Hop-Ups 6 03-08-2004 04:35 PM
Help! Skyline not working right SkylineGT-R_man XMODS Parts and Hop-Ups 3 12-04-2003 04:00 PM
rsx to skyline VaTifosi XMODS Parts and Hop-Ups 1 11-27-2003 01:29 AM
Blitz Skyline clone body up for trade(custom lip) Superimport2nr Bit Char-G / MicroSizers 2 01-09-2003 10:26 PM
