Old 11-22-2003, 02:12 PM
ZipRC's Avatar
ZipRC ZipRC is offline
Modder-Eater
Need help with my FnF Eclipse
I bought the 1/25 Fast and the Furious AMT Eclipse model kit. I haven't started building yet because I don't have any paint, but already I've run across problems:
the wheelbase is just a little bit larger than the longest wheelbase setting, and I don't know what to do. any help?
Old 11-24-2003, 03:02 PM
mbartell mbartell is offline
so I re-wired it
Well whatever you do, don't cut it thru the middle.
Looking at it, the places you could cut the body would be right behind the doors.
Then, keep the top in one peice, sliding it back on the trunk.
Use tape cut to the length you want to shorten it, and lay a strip on the side, and annother on the trunk.
You will have to make a cut on the body so that you can take up the slack, and keep things somewhat alligned.
Use normal model glue to put it back together, and a small peice of thin styrene behind the cut to re-inforce the area.
Squadron makes the best putty for model cars, and that's what I swear by.
It's not going to be instant. You will need to sand, prime and fill quite a few times to get it right- you don't want to rush it, or it'll look really bad.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
Old 11-24-2003, 05:14 PM
dragon4450's Avatar
customanix
what i would do is figure out a way to extend the wheel base with like a strip of metal or a strip of plastic at the mounting points. then i would get a metal tube from a hobby shop and make a new axel for it. i sugest a tube over a rod tho cos it will be easier and as long as you dont get the aluminum tube it shout be better then stock. the hardest part of it would be mesureing for the new axel.
Brian's Eclipse, in RED CivicNation ZipZaps 8 06-13-2004 03:36 PM
X_MODS 99 eclipse GST skyline-99 XMODS 19 12-20-2003 02:47 AM
Poll: FnF Eclipse or Unique ZipRC XMODS 8 11-23-2003 06:23 PM
Has anyone lowered the eclipse or added LEDs? zacdaddy ZipZaps 3 10-09-2002 05:33 PM
