Old 09-24-2002, 11:28 AM
Namuna's Avatar
Namuna Namuna is offline
Bit Steering 101
Welcome to Bit Steering 101. Today we will be going through the components and terminology of the steering system used in the Bit (which is the same for MicroSizers, ZipZaps and the clones).
Note: The images used are from Ausmicro, I've only added the text.
First up, disassemble the car and unscrew this small screw to access the Steering area.
Old 09-24-2002, 11:29 AM
Namuna's Avatar
Once you've taken out the screw, gently pry the Stabilizer Assembly off.
The Stabilizer applies tension to the Travel Arms (you'll see what this is below) of the Front Wheels, this is the Bits' suspension system. You can purchase Stabilizer kits that have several Stabilizers, each of which applies more or less tension.
Old 09-24-2002, 11:31 AM
Namuna's Avatar
Once that's off, you now have a view of the inner workings of the Bit Steering System.
Let's start taking out the pieces...
Old 09-24-2002, 11:35 AM
Namuna's Avatar
Next thing to come off is the Steering Arm, the integral part of the steering system.
From the picture above; when the Steering Arm is pulled to one side, the Steering Spring is also expanded to that side...Once you let go of the button on the controller (and the magnet is released) the Steering Spring does its' job and pulls the Steering Arm back to the center position.
Note: A common problem with steering on the Bit is that the magnet on the Steering Arm will get jarred slightly off-center. If you do notice this problem with your Bit, it's a good idea to recenter the magnet (you can even consider using super-glue to make sure it stays centered)
Old 09-24-2002, 11:37 AM
Namuna's Avatar
Alright, with the Steering arm out, here's a look at what's left.
We're going to take the wheels off next.
Old 09-24-2002, 11:39 AM
Namuna's Avatar
Here's a closer look at the Front Wheels.
Steering is done via the Steering pin, which is interconnected with the Steering Arm. When the Steering Arm is pulled to one side, it in turn pulls the Steering pins of the front wheels.
Another thing to check for (if you're having steering problems) is that there's no debris on the travel arm (upper or lower) and that the wheels spin freely.
Old 09-24-2002, 11:41 AM
Namuna's Avatar
And lastly, here's the bare inner parts and a look at the 'magic' of how steering works on a Bit.
When you press a controller button for left or right...It in turn activates the *coil and pulls the magnet on the Steering Arm to that side.
The Steering Coils should be neat, compact and in its proper place.
*For folks that might not have done the experiment in school; if you coil wire and then send electricity through it...you turn it into a magnet, and when the electricty is turned off, no more magnet.
Old 09-24-2002, 11:44 AM
Namuna's Avatar
Alright boys and girls, that concludes our class for today. Hopefully you now have a better idea of what the Steering system looks like and an idea of how it works.
Stay tuned, I'll be adding animated gifs of the steering system in action (so you can SEE how it works, not just read about it)
Old 09-24-2002, 03:27 PM
mcbusiness's Avatar
mcbusiness mcbusiness is offline
Send a message via ICQ to mcbusiness Send a message via AIM to mcbusiness
Awesome job Namuna!
Taking questions from the class?
Just me and my bits
Old 09-24-2002, 03:29 PM
Namuna's Avatar
Always glad to answer questions, fire away.
Old 09-24-2002, 03:32 PM
payaso payaso is offline
BIT PIMP
Cool, Can I be excused to go to the bathroom??? LOL
My name isn't payaso for nothin...
silla
Old 09-24-2002, 03:43 PM
CaboWabo
*Cabo throws spit ball on back of payaso's neck*
teehee
Old 09-24-2002, 03:47 PM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
hmmmm
(*throws a butcher knife at the back of CaboWabo's head*)
MWHAHAHAHAHAHAHAHAHAHAHAHAHA
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
Old 09-24-2002, 03:50 PM
CaboWabo
*Cabo raises hand to tell teacher*
neiner - neiner - neiner!
Old 09-24-2002, 03:58 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
*MTL falls asleep
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 10:04 PM
Dropped my BIT, now steering is out delaroca Bit Char-G / MicroSizers 8 12-12-2002 05:54 PM
Bit Propo Steering idea Dracos Bit Char-G Mods and Projects 0 11-06-2002 11:40 PM
