Old 11-04-2003, 05:52 PM
guce guce is offline
Send a message via AIM to guce
lights
an idea about how to make underglow.. get a small straw and put a light in each end from your light kit, wrap top half w/ tin foil and then glue it to body where you prefer.
Just an ideah!
DCS Douglas County Style
Old 11-05-2003, 03:46 PM
viperkilla's Avatar
Re: lights
Just an ideah!
I dont think that this will work, because there isnt enough ground clearance.
Old 11-05-2003, 10:13 PM
FLMX647 FLMX647 is offline
It might work in the front and back tho that would be sick....good idea
Old 11-17-2003, 04:00 PM
Stormvet's Avatar
Stormvet Stormvet is offline
Paint X-fer?? UP YOURS!
You might be able to do it if you can find a small enough plastic tube. You're going to need to be down around 2mm though.
OUCH!
Good Luck!
StormVet
Freedom will be defended!
2003 RSX - Silver
Stage 2 (Blue)
Bearing upgrade
Suspension Upgrade (Hard rear - Soft Front)
Tire Upgrade (soft treaded)
AWD
Modded with alt-flashing red & blue LED's (Police lights in grill)
Old 11-17-2003, 08:15 PM
sunfirerep601
Hey guys... I'm testing something soon so i will post how well it works. If my method now doesn't work i'll try other things.
Command Logic Lights MODS drewdown84 XMODS Mods and Projects 4 07-30-2007 01:33 PM
glow lights on car SkylineEvo XMODS Mods and Projects 0 11-12-2003 12:48 AM
running lights from car battery esp rocker Bit Char-G / MicroSizers 4 06-24-2003 01:23 AM
putting lights in my car xatu Miscellaneous Discussion 12 06-04-2003 12:06 PM
Lights and Bit Char-G DigitalAce7 Bit Char-G / MicroSizers 1 11-08-2002 03:45 PM
