01-18-2004, 10:05 PM
DRIFT KING
WRXmod, Junior, well i got one too.
i just got this from tower hobbies and i decided to post the pics, i had to make a drive shaft and the usual dremel job, but it was a clean fit, here's the first....
I don't care if you can you beat me in a drag, I'll own you in a drift match.
01-18-2004, 10:06 PM
DRIFT KING
the second...
01-18-2004, 10:07 PM
DRIFT KING
and the third...
01-19-2004, 06:31 AM
I did the same thing last night. How did you secure the front, which xmod did you start with? I started with the supra and the front clip is too wide. With the slot sitting on the clip it fits good, but how did you do yours.I have velcro on the sides.
01-19-2004, 12:12 PM
It looks even better than I thouhgt it would. It's no the Civic chassis, right? And are those Skyline wheels?
Mazda Savanna RX-7
stage 2 motor | spaced wheels
01-19-2004, 08:39 PM
DRIFT KING
yeah it's the skyline, but i used the civic front clip for some extra clearence, and it was easy enough, i put velcro on it but i only put the fuzzy side on the batt clips, so it fits nice and snug, the rear i just put a post in between the 2 suspension mounts and put some foam on it so that it didn't scratch the body.
01-19-2004, 11:27 PM
How would it look if you put the rear wheels on backwards so they filled the rear fender wells a bit more?
Just a suggestion...
01-20-2004, 12:08 AM
DRIFT KING
yeah, i'm planning on modding the mini-z wheels that cam with it, they have a bigger offset so they will fit the rear wheel wells just fine, but i was thinking about that option too.
01-21-2004, 12:05 AM
DRIFT KING
cool, i just got the miniz rims on mine it look so good it's not even funny, i'll try and post some pics later, i'm going to bed.
05-11-2004, 11:10 PM
JDM Enthusiast
Sweet.
J . D . M
05-12-2004, 09:00 AM
DRIFT KING
i actually fabricated a rear mount, i took the clip that came with the miniz and atatched it to the body cli of the xmod and it fits perfectly now.
05-13-2004, 02:59 PM
Xmoddin' Freak
How did you get the mini z wheels to fit? Did you modify the center of the wheel to allow for the "D" shape? I'm thinking about purchasing a couple sets of wheels and then using either epoxy (for plastic wheels) or JB Weld (for metal ones) to fill in the round hole and create the "D" shape with an extra driveshaft.
Please, do tell how you got the wheels to work and post a couple of pics, if possible.
Greg
Red Supra/New Beetle RSI, AWD, Full Bearings, Team Orion Micro RS4 Stock 180 (10 tooth), Team Orion Micro RS4 Stock 180 (20-tooth), Carbon Fiber Driveshaft by Sluggbug, Metal Lock Nuts, Lithium Ion batteries from AtomicMods.com.
05-14-2004, 06:02 PM
DRIFT KING
i can't post them cause i broke them, but all i did was space them out abit and cut the inside hub a bit then got some plastic and put the d shape in it, and eposied it in.
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
WR(X)MOD......get it.....
pigeonfarmboy |
XMODS Mods and Projects |
44 |
02-01-2004 09:37 AM |
