07-10-2003, 05:48 PM
not so bright
engine and gear test results
today i did a test on which was best and i figured that the yellow zipzap motor with green or red gears are best for speed but not handling
deace out
07-10-2003, 05:57 PM
Tiny RC Guru
i beg to differ
not 2 b mean but i beg to differ the fastest setup is Nos. Ex. with teal (fast) Microsizer transfer gear with the red Zip Zap axel once again not to be mean wouldnt wont to be on your bad side or nething
07-10-2003, 06:02 PM
not so bright
lol i dont see what could be mean about it but i shouldve cleaned my nos motor better before running it in the test cause it still had some hairs...which i guess made it slower, thank you
deace out
07-11-2003, 03:17 PM
phear meh..............
the nos xpress motor is pretty fast, but the king 4.2 is faster
but if speed is all you want, do the mosfet mod on just the forward h-bridge
07-11-2003, 05:49 PM
Re: i beg to differ
Were you aware that they are exactly the same thing?
Both the MS teal and the ZZ red are 8.25:1 ratios.
My fastest has been with the purple motor and the 8.25:1 gearset. It's generally the gearset i use on everything except dual cells. i use 9.86:1 on those for more control.
07-11-2003, 05:53 PM
Anime RPG Nut
What is Mosfet
07-11-2003, 06:06 PM
not so bright
deace out
07-11-2003, 08:13 PM
Tiny RC Guru
i beg to differ
they are not tha same strider_mt2k tha teal meshes togetther better i agree its tha same # of teeth but it meshes together better like i said earlier, not to mean be i hate people to be mad at me
07-11-2003, 09:03 PM
thoeretically they are the same gear ratio and all, and i find that certain clone gears mesh better with the ms pinion gear
but who cares, if you got no handles, then go straight all you want
07-11-2003, 09:54 PM
All I use are the black 6 tooth pinions that MS seems to put in every accessory kit. Well, that's not true, strictly, as I use the Zip Zap too.
I haven't seen much diff, but I'l try mixing them up to see.
It is an interesting idea. I suppose I could look at them side by side under a microscope at work too. Not that I'm an expert.
Actually the assumption that they are made idetically, or by the same company was all mine!
11-15-2003, 10:55 AM
It's Nitrous Express, not NOS Express. Nitrous Oxide Systems (NOS) and Nitrous Express (NX) are competing companies both selling nitrous oxide.
