Old 10-30-2003, 07:02 PM
food123 food123 is offline
New. Please help!
Hey everyone. I'm about to buy an xmod. Is is worth it? I'm new to the RC world, and I need some suggestions. Also, could someone give me a link to the official mini z site? Thank you
Old 10-30-2003, 07:07 PM
Can someone also explain to me how gear ratios work? (I'm 15, I have no idea what I'm doing) thank you
Old 10-30-2003, 07:17 PM
One more question (sorry about all these) Can parts from xmods be mixed with other companies?
Old 10-30-2003, 07:18 PM
Got 4.2 King? I do : )
i'd say there worth it
and with gear ratios, the lower the number the higher the top speed. the higher the number the faster the acceleration
if you divide the rpms by the gear ratio you'll find the speed the wheels spin at (if there is no drag)
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 10-30-2003, 07:24 PM
thanxs sorry for being such a newbie
Old 10-30-2003, 09:22 PM
The Setup I'm thinking of buying Black Honda Civic, light kit, 2nd motor kit, or should i spring for a mini z engine?
Old 10-30-2003, 10:10 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Not too shure there. For the ultimate speed, you want to upgrade your speed control (any number of ways to do this) and either buy a high-powered motor online or rewind your own. If you check the www.minizracer.com site, you can find a ton of motor-related information.
But yes, the stage 2 will be plenty fast. Cheap (compared to min-z stuff) too.
Old 10-30-2003, 10:13 PM
if you plan on turning with the stage 2 be careful. i had blue gears with stage 2 running with energizers and i turned sharp and i think the wheels caught on something in the street. i rolled my skyline atleast 5 times on that one turn. it was hard to count it spun real fast
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 11-02-2003, 04:06 PM
how do i wind my own motor?
Old 11-02-2003, 11:01 PM
Nathan's Avatar
Bad Driver
It's a long story. But you need a pinion puller before you can do anything. Find one from a hobby shop that sells slot cars.
Once you have one, take the pinion off, desolder the caps from the motor can, and bend the metal tabs out to open it. Remove the armature, desolder the wire on it, and replace with slightly fewer turns of slightly thicker wire. Don't go overboard. Re-assemble the motor, solder the caps back on, and press on the pinion.
Easy, huh ?
Old 11-03-2003, 06:33 AM
4G63T's Avatar
4G63T 4G63T is offline
got boost?
lmao!
All Wheel Drive=Fun!!!
Old 11-03-2003, 12:11 PM
dragon4450's Avatar
customanix
you have that backwards. the lower the number the better the acceleration and the lower the top speed. the higher the number lower acceleration but better top speed.
Old 11-03-2003, 04:40 PM
thanx guys
Old 11-03-2003, 04:42 PM
I'm buying a black honda with 2nd motor upgrade, lights, and suspension, on friday. I'm still debating the mini-z's though...:-Ąz
Old 11-03-2003, 05:09 PM
4G63T's Avatar
got boost?
don't debate buy xmods there are a lot more fun
