06-23-2006, 03:10 PM
6 cell project
Ok I am planning on doing the 6 cell upgrade and I was wondering where do I connect the wires on the battery pod and do I wire it up in series or parallel..
and one more thing where did you evo guys mount the pod
06-23-2006, 07:13 PM
If you wire in parallel, you're going to need 8 batteries. You have to wire them in series.
What I do is unsolder the red power wire from the pcb and run it to the top. I use that to run to the negative of the extra battery holder. Then run the red wire back and solder it to where you took the original off. I just leave the batteries on the top of the chasis. Once the body is on, it seems to stay pretty snug.
06-23-2006, 07:21 PM
cant I just heat up the soilder on the pcb board and connect the red wire with the red and the black with black?
06-23-2006, 08:56 PM
Nope, that will acutally try to force current through the other two batteries then. You have to break the connection and wire them in series.
06-24-2006, 07:03 AM
ooo ok so.. by you saying.. What I do is unsolder the red power wire from the pcb and run it to the top. I use that to run to the negative of the extra battery holder. Then run the red wire back and solder it to where you took the original off. I just leave the batteries on the top of the chasis. Once the body is on, it seems to stay pretty snug .........
what do you mean when you say "unsolder the red power wire from the pcb and run it to the top"(top where??), same here"Then run the red wire back and solder it to where you took the original off (back where??)
06-24-2006, 08:13 PM
Originally posted by racer15
Hi, im new here, so i may need help getting around
i want to do the same project, but i have no clue what you guys are saying, and i dotn have a soldering gun or anything,
any way i can still install my 6 cell upgrade?
yes there is .. I found a tutorial which i am going to use and instead of connecting a plug to the wires on the board I am connecting the battery pod it self to the wire.... http://www.geocities.com/cjoe8090/EV...?1129609504250 ...
just follow the links for what you need
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Tri cell mod.
RobotGT |
Tips, Mods and Reviews |
1 |
02-24-2010 04:27 AM |
Project 4 Cell
Yell03SpecV |
XMODS Mods and Projects |
15 |
01-31-2004 02:17 AM |
Tri cell mod
RobotGT |
5 |
09-25-2003 04:22 PM |
Tri cell mod
RobotGT |
Bit Char-G / MicroSizers |
3 |
07-27-2003 11:06 AM |
