Old 11-03-2003, 08:48 AM
merc merc is offline
5th cell... has anyone seen this?
I found this guy trying to sell this xmod with 5 cells. This is what he wrote:
"A holder for a fifth AAA battery. These were made to use 4 AAA batteries. If you use standard 1.5volt non-rechargeables that is 6volts. If you use NiCd or NIMH at only 1.2volt per cell you end up with only 4.8v. This modification will let you add a fifth nicd or nimh cell to get a full 6Volts! This has not been tested with 5 alkalines which would give a whopping 7.5v, you can try that at your own risk for even more speed."
I was wondering if anyone else here has seen anything else like this or has tried it.
Old 11-03-2003, 08:51 AM
EMX's Avatar
EMX EMX is offline
I R r33t Hick
Send a message via AIM to EMX
It wouldnt be that hard,
what is the max voltage these things can take?
Old 11-03-2003, 08:58 AM
Not sure. He doesn't sound that sure about useing 5 1.5v aaa's. But i thought it would be kind of cool to get the 1.2v's back that you lose useing the rechargeable nihm's.
5th cell problem, 5th cell heating? robehsi XMODS 3 07-16-2004 11:30 PM
FET and motor heat build up with 5th cell? RGM1524 XMODS Mods and Projects 1 01-08-2004 04:14 PM
I need help with a 5th or 6th cell installation... Chaos Fire XMODS Mods and Projects 3 12-24-2003 11:00 AM
