Old 09-19-2003, 05:46 PM
Mr.Qla
lagging?????
ok heres ma problem ma car when running kinda lags!!!!!!!!! like go stopy go stopy go ya kno like laggy its REALLy laggy well not really but it still is wats tha problem?????????
Old 09-19-2003, 06:24 PM
ib311's Avatar
ib311 ib311 is offline
Promoted to Pleb
i'm going to guess a few things.
1. your car has traveled out of it's range from the controller
2. you have frequency from other things in the room messing with your car's frequency and it's causing it to get a read and no read and read and no read.
3. you have some hair wrapped around the gears or motor.
4. your pushing forward and then letting off the button then pressing forward again.
you can choose which answer you like best.
Old 09-19-2003, 09:48 PM
Yukioto Yukioto is offline
Send a message via AIM to Yukioto Send a message via Yahoo to Yukioto
I used to have a really good Clone Car, but now it does that too, especially when it tries to turn... Its worst when its going reverse AND turning... I check everything, hairs, dust in gears, battery etc but it still sucks
Old 09-19-2003, 11:35 PM
Awaken's Avatar
Awaken Awaken is offline
Feh
Send a message via AIM to Awaken Send a message via Yahoo to Awaken
did you check the battery contacts and see if they arnt touching very good? try bending them in more and putting the battery back in..hope that helps
Give me a moment in which I well never AWAKEN
Old 09-20-2003, 11:14 AM
Mr.Qla
ok... it could not of travveled out of its range cuz im only like 4 feet away from it.............i dun kno about the same frequency in the room but i think thats the problem and is there anymod i can do to get better reception???
Old 09-24-2003, 05:23 PM
Mr.Qla
help!!!!
Old 09-24-2003, 06:51 PM
payaso payaso is offline
BIT PIMP
What brand car is it? You can swap out the antenna for a better one.
silla
Old 09-24-2003, 09:07 PM
Mr.Qla
tomy tomica bit char-g
Old 09-25-2003, 02:41 PM
BIT PIMP
Which Tomy is it? What Mhz? Check the batt in the car to se if it's making good contact, and then you can untie the antenna knot under the PCB. This will give you more length for better reception..
How many times in a row are you charging? Charge it about 5 times in a row, and see if that helps it out..
Good luck...
silla
Old 09-25-2003, 05:35 PM
Mr.Qla
i do charge it like 5 times!!!!!! its a 37 mhz and um.... the battery is not loose or anything...and i already untied the antennna
Old 09-25-2003, 06:08 PM
BIT PIMP
Do you mean 35mhz? There is no "37"
The only other thing I can suggest is to unsolder the antenna, and put a new one on there.
I guess you could also try re-seating your motor in it's bay. Try giving it a 1/4 turn, and then try it again..
silla
Old 09-27-2003, 11:11 AM
Mr.Qla
alrite but for unsolderding the antena and then soldering a new one....does the antena have to be like a bunch of copper wire antena or like a thick long peice of coper antena witch one would work best
Old 09-29-2003, 04:33 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
a piece of wire from the inside of a CAT-5 network cable
Old 09-30-2003, 08:22 PM
pa0
did you mean 27 or 37? i have the same exact problem with my 27 mhz microsizer. i used to have an 27 mhz evolution and i brought it back to the store and got a 27 mhz s2000 but it still did the same thing. im thinking theres something wrong with the 27 mhz microsizers?
Old 09-30-2003, 10:08 PM
fireball16789 fireball16789 is offline
yah the same thing happened with my 27 mhz. one i tried messing with the antena but it came of, along with all the other wires. I bought another 27mhz and that one doesnt work either. My friend bought a 49mhz and it had no problems and got more than twice the distance of mine. can anyone explain this?
Ferrari Modena- perfection 4.2
