Old 08-29-2003, 11:44 AM
DraGula's Avatar
DraGula DraGula is offline
TinyRC fool!
Yet Another speed Mod
This mod is very easy, but requires the use of a soldering iron.
1. desolder or rip off where shown.
2. connect the two points left after the part is removed.
3. charge and watch it go!!!
the boost of speed from this mod is minor, but i havent found any downside to doing this though.
(thanks to namuna for the use of the pic!!)
I command you to: check out the site
Old 08-29-2003, 12:49 PM
Tazzy Tazzy is offline
Enlighted
Send a message via ICQ to Tazzy
I've got a shen qi wei with a PCB that looks the same but I don't have the fancy text nor the black blob... should I go ahead with this mod?
Old 08-29-2003, 01:58 PM
BabyKiller's Avatar
and what does this do take off a resistor to allow more voltage to the motor in other terms a simple semi mosfet?
+ (4.8v)
Old 08-29-2003, 07:02 PM
FoeverClownin's Avatar
FoeverClownin FoeverClownin is offline
Send a message via AIM to FoeverClownin
do u have a version for the big lots thunder charger clone
Old 08-30-2003, 01:57 PM
DraGula's Avatar
TinyRC fool!
i didnt test the voltage output yet, it should be higher, and this will probably work on clones, it will do the same thing to their electronics.
Old 09-03-2003, 05:35 PM
RobotGT's Avatar
RobotGT RobotGT is offline
SUPREME RULER
would one glob of solder connecting the 2 points work. im really concidering trying this! good pic and directions
full size zz wheels
Old 09-03-2003, 06:59 PM
DraGula's Avatar
TinyRC fool!
of course one glob of solder would work, you just need to connect the points.
Old 09-16-2003, 06:43 PM
Clownn Clownn is offline
i just finished doing it put i did not connect the two points and it still worked do i have to connect the two points so it can work good??
Old 09-16-2003, 06:51 PM
i just took it for aride ant the reception is the worst it wont even go 2 feet
Old 09-17-2003, 05:02 PM
DraGula's Avatar
TinyRC fool!
that's strange, i didn't notice any range loss when i did this.
Old 09-17-2003, 05:03 PM
i had to go exchange it for a new one in target
put of course striped it compleatly
The Infinite Speed Potentiometer Mod (tm) actofgod Bit Science 46 09-16-2003 05:47 PM
Dual cell mod ( will 2 - 50 mah's achieve + speed?) Suntzu28 ZipZaps 7 01-11-2003 10:57 AM
dual battery mod no speed increase? delmonk Bit Char-G Mods and Projects 7 10-17-2002 01:10 AM
Speed Boosting ZZ PCB Mod gpile ZipZaps 4 10-11-2002 07:43 PM
Found a great new speed increasing mod! st5150 Bit Char-G / MicroSizers 15 09-21-2002 06:51 PM
