Old 07-31-2003, 03:26 PM
Got 4.2 King? I do : )
gear on the moter
stock all the motors have 6 but i'm hearing of haveing 7 and 8 to drop the gear ratio
where could i find some of these?
pinion gear i think their called
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 07-31-2003, 04:46 PM
MicroSpeed's Avatar
you can get 7 tooth pinion gears off KIT racer motors, but they dont work too well with normal gears. Never heard of 8T though
Old 07-31-2003, 04:49 PM
oh i was wondering if i could buy one, or i could get a five finger discount on a pinion gear if i find a car with one. dont watn to buy a whole clone to take a littel piece of plastic
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 07-31-2003, 04:59 PM
payaso payaso is offline
BIT PIMP
Ripping off the part you need is NEVER the correct solution. You can buy the 7 tooth pinion gears from "Toyeast" they come with "Bit Racer" motors ie. 3.0 Lucifer Rotor.
You can also get them from "Hot Wheels" K.I.T.T. racers..
You can also look for some clones for different gears.. I've seen up to 10 tooth gears on "Cannon Balls"
Hope that helps..
silla
Old 07-31-2003, 11:53 PM
boho's Avatar
boho boho is offline
Camera springs
I've got 7 tooth pinions. They don't fit correctly, as stated before. Buuut, I took a clone and made some extra room in the motor compartment so I could adjust the motor for the bigger pinion. I used diferent types of electrical/duct tape for spacers. The result; Not so exciting. A little faster, but not by much at all. I think it had less torque too.
Custom Crawler Gear Mod hartoy53 ZipZaps Monster Truck 3 06-30-2008 03:44 AM
Wheel Weights! Steve ZipZaps Monster Truck 54 05-24-2006 01:40 AM
"the need for speed: a fast MT gearbox" chilli_mp138 ZipZaps Monster Truck 1 12-20-2005 06:58 PM
The maximum gear ratio..... charliebrown ZipZaps 9 01-13-2004 04:55 PM
Equation for scale speed and gear ratios. Zephyranthes Bit Char-G / MicroSizers 0 02-10-2003 07:34 PM
