Old 07-15-2003, 01:15 PM
jamgunner jamgunner is offline
Wannabe TinyRC Pro
Send a message via AIM to jamgunner
gears wont mesh properly
every now and then the pinion gear and idler gear on my lxx booster locks up and i have to manually spin it to get it to start working again. how can i fix this???
edit
also when it is running why does putting the body on make it stop?? i cant see where it would be making contact with any moviing parts
Old 07-15-2003, 01:52 PM
dr1zz's Avatar
dr1zz dr1zz is offline
phear meh..............
had the same problem
one solution was the motor position didnt make the pinion gear mesh good with the idler gear. a shim fixed that problem
another time it was just crappy gears.
and about the shells, hmmmm.....what shell are you using, alot of my supra shells are tight around the wheels.....
Old 07-15-2003, 01:54 PM
Char-g Ace's Avatar
Char-g Ace Char-g Ace is offline
I need to change my Title
if you have had the lxx for a while like a month and modded it the chances are that it is just worn. I had one and replaced the gears with microsizer gears at toys r us. also try using a more powerful motor
4 Bit Char-g Failiers
1 Microsizer
3.8 motor
Duel Cell sucess
Celica body
Old 07-15-2003, 02:57 PM
Wannabe TinyRC Pro
brand new outa the box but still good call on the crapy gears. couple of the teeth were a bit lop-sided so i replaced it and runs great now. and yes i am using a supra body. also i am using the yellow zz motor(decent unboosted, prety crazy boosted).
Selling lots of gears and moters pain899 For Sale/Trade 19 09-30-2006 10:17 PM
Pinon gears. dje7447 Bit Char-G / MicroSizers 7 10-09-2003 03:52 PM
LXX Gears Suck...need better ones! Bobo For Sale/Trade 0 06-27-2003 08:23 AM
clone gears vs bit gears ? Mike the Great Bit Char-G Parts and Hop-Ups 10 01-19-2003 01:05 AM
Unexpected gear mesh Fix!!! cowfish_29 Bit Char-G / MicroSizers 4 10-13-2002 01:55 AM
