Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer Parts and Hop-Ups
Old 02-19-2003, 06:31 PM
Tch0rT Tch0rT is offline
Just my luck a bent rear axle...
Just my luck... I got my HPI Micro Mod 45T Motor yesterday in the mail. I installed the new motor today and took it outside in a parking lot to test it out. I didn't even drive it around for 5 minutes and I flip/rolled my DRR and it bent the rear axle. Anyone know of any quick fixes? Is trying to straighten it an option? There's probably no way I'll be able to make it 100% straight if I tried to bend it back.
Thanks,
Ryan
Black NSX GT1 Dynamite Rocket Racer
7.2v BLiND Batteries Battery Pack http://www.blindbatts.com
HPI Micro RS4 Mod 45T Motor
HPI Micro RS4 14t Pinion
ABC DTM Bearings
ABC DTM-SP Foam Tires
Dynamite Aluminum Body Posts
Foam Insulation Home Made Bumper
31MPH or 50 km/hour
Green Lamborghini Murcielago MicroSizer
Rare Earth Magnets & Steering Spring Saver Mods
Old 02-20-2003, 03:18 AM
crusader4x crusader4x is offline
You can buy a replacement axle HERE . I did a search for "dynamite axle" and found it quickly. Less than $5.00.
Old 04-12-2003, 10:41 PM
Spongebob Spongebob is offline
Ooh! I have an Idea! Take a welder's torch, and heat the axle up, and then bend it back! Whoa! I had way to much caffiene today!
Rear Axle Bearing I-luv-Goin-Fast ZipZaps Mods and Projects 0 03-28-2005 01:58 PM
Repairing a worn rear axle retaining slot rfnagel ZipZaps 5 01-22-2004 01:37 PM
Rear Axle Tip nrmcj Bit Char-G / MicroSizers 8 05-18-2003 01:47 PM
heres a simple solution incase your rear axle doesn't snap into the mounting points spikeymike218 Bit Char-G Mods and Projects 18 02-16-2003 09:24 PM
ZZ rear axle wheels on front of BIT? Also willing to buy a set of front ZZ wheels. SPEED Bit Char-G / MicroSizers 0 09-27-2002 06:40 PM
