Old 06-17-2003, 03:32 PM
maxximum attack
Question...
Can I run the Mini-Z on wet concrete? More specifically, wet enough to make water flick from the tires. Not damp.
Old 06-18-2003, 03:07 PM
Hooters Driver Hooters Driver is offline
Not if you value the electronics in it. While I haven't tried it with a mini-z I did run my mini-x through some water that had been spilled on the floor (very small puddle). Just a few seconds later it stopped running so I picked it up and turned it off. After inspecting it to see if there was a problem I turned it back on and tried to drive it. Within seconds I saw smoke coming from the electronics and I immediately turned it back off. After using compressed air to dry it out I turned it back on and, thankfully, it ran OK. I now consider myself lucky and always make sure my floor is completely dry before running.
Old 06-18-2003, 07:09 PM
maxximum attack
Thank you for the VERY graphic warning. I will definately heed it. I haven't got one yet but i plan to very soon tho.
Thanx again
Plz Look!! Slipper And Or Tranny Question! lilrichie1306 Micro-T General 3 01-24-2008 02:22 AM
Question, please awnser quickly. Supra-00 Bit Char-G / MicroSizers 17 10-25-2002 11:32 PM
Question about model putty... SPEED Bit Char-G Mods and Projects 1 09-28-2002 10:19 PM
Question about fullsize wheels set Mod..? SPEED QFM Racing Customer Support 5 09-25-2002 11:26 AM
