05-13-2003, 07:43 AM
Antenna Idea
I've read where people have made internal antennas that run inside the body of the car. Has anybody tried using an old steering coil from a dead bit, and using the coil as an internal antenna? It seems like a steering coil would make for one hella’ long antenna.
05-13-2003, 10:39 AM
Retarded Stunt Driver
never done that but you are probably correct.
05-13-2003, 01:53 PM
what i do is wrap my antenna in tin foil and curl it up and place the body over it without the anteena sticking out and i get a extra 4 feet while its under the body
05-13-2003, 03:23 PM
i havnt ran my cars with antennas stickin out since right after i got my first or second car.
you get so much better performance.
05-13-2003, 04:26 PM
Feh
so is the wieght of wrapping foil around the antenna worth it?
05-13-2003, 04:56 PM
a piece of foil aint that heavy
05-13-2003, 05:55 PM
Feh
will it might be to a bit
05-13-2003, 07:08 PM
Actually, they suck^
dude even to a bit, foil weighs nothing. sounds like a good idea to me... im gonna try that
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Toy East Mini Cooper
1 Precious Clone
05-13-2003, 07:12 PM
if it has any affect it would give it better traction and preformence
05-13-2003, 09:23 PM
Feh
ah ok heh i guess if your put alot it would be heavy...
05-13-2003, 11:18 PM
MASTA POOOOOOOOOOOOOOTANG
how many times do you wrap it in alluminum foil?
MICROSIZER PRO:  2 SPEEDS, 1.3 NIMH, 49 MHZ, SKYLINE R34 GTR custom paint, pull back wheels, blue head lights
MICROSIZER SPORT:  1.3 nimh, rest is stock
panther=  2.4 nicd, rest is stock
MEGATOYS rc:  rest is stock
bitchar-g:  rest is stock
05-13-2003, 11:29 PM
Feh
i guess once? and do you have to have the antenna wire touch the foil r just wrap it around it?
05-14-2003, 06:15 AM
lol i do it like 5 time then grap each end and twist in opposite directtion to make in as thin as possible
05-14-2003, 12:56 PM
Feh
ah i see
05-14-2003, 02:22 PM
good idear babykiller. cant believe i said that. heh
