I was trying to fix my ZZ yesterday and my soldering iron fell off the stand. It burned the carpet making a shape of the metal part into my carpet. It is all hard too. How do I fix this?
Here's a solution for you Zephyranthes. Get some carpet tape and cut a round peice of carpet from a closet then cut the same size peice from damaged area and use the tape under the carpet to make the patch. Move your hand over the carpet so you can make sure it lays the same way and you will never know it was patched. Of course put the damaged peice in the closet and no one will ever know wha you did.
