Old 04-22-2003, 09:21 AM
soggyrice.mMmMm soggyrice.mMmMm is offline
Lightbulb My extended range mod ;x
No pics, but if you have a short antenna...instead of spending your time and money on the equiptment and soldering a new antenna. You can always use...
(drumroll)
aLuMiNuM foiL!
Remember when we(or some of us) used foil on our tv antennas when we didn't have cable?
sure you'll get remarks like..."(name here), daym, that's ghetto"
but in the end, if you don't have the time to solder, buy equiptment, or even mess up your controller...this is the mod for you.
LAZY AZZ! ;D
Old 04-22-2003, 10:09 AM
BabyKiller's Avatar
lol anything metal to extend it should work
+ (4.8v)
Old 04-22-2003, 10:10 AM
BabyKiller's Avatar
btw soggy rice is for the ghetto
+ (4.8v)
Old 04-22-2003, 10:22 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
how much do you use? how well does it work?
Old 04-22-2003, 11:17 AM
:D
I used about 6' and my range went about 40-50 feet from 20 feet originally. I gotta try measuring it, but once you make the antenna+foil so long, you won't see any range improvement.
Old 04-22-2003, 01:21 PM
bwsk8's Avatar
bwsk8 bwsk8 is offline
NSX Driver!
I used a paper clip once. It worked but slowed the car down.
Old 04-22-2003, 03:01 PM
BabyKiller's Avatar
hmm i wrapped the antenna on the car with it then twisted it to make it thin i curlled it into a coil and tucked it under the body with the sorta internal antenna mod i got around the same too like an extra 3 feet of distance with the anteena in the car i got like a extra 4-5feet with it sticking out though mine was kinda thick so it weighd it down and whenn it was sticking out the center of grav was messed up
+ (4.8v)
Old 04-22-2003, 11:13 PM
SlowbutCourious's Avatar
State Property
..and i spent all of that time( 8 min. ) puttin 2 antenas on that controler 2 get 43 ft..and all i needed was some FOIL.. LOL.. that is GHETTO but what isnt..
Extended Range? aperson XMODS 57 10-08-2004 11:16 AM
Steering Range Fix: Mod the Tierod ikinari XMODS 28 03-31-2004 10:50 AM
S.R.M (Super Range Mod) ph2t Bit Char-G Mods and Projects 10 04-16-2003 05:10 PM
the easiest range mod ever!! (it aint really a mod tho...) CrAp Bit Char-G / MicroSizers 15 11-17-2002 09:48 AM
controller mod & solution for poor range natedogg4674 ZipZaps 4 10-13-2002 09:40 PM
