Old 04-14-2003, 02:59 PM
BabyKiller's Avatar
Lightbulb I have a modding idea
unless you could figer out how to keep steering and do this you wont beable to steer its a duel/tri motor(if you keep the back) but you install it on front wheel for fwd
i was thinking tou could get 2 of the same gearsets you dont want and take the gear off the axel. then get one on each front rim and lock the steering up. glue the motors (or attach somhow) right above the gear. make sure it comes in contact. then connect the to motors together and run wires to the back.solder them on the blue and white wires which run power to theback motor and try it out
+ (4.8v)
Old 04-14-2003, 03:47 PM
BillyP
Wow... I think I actually understood that!
I think that's too much work. You can put three or four motors in the back. The problem would be getting enough power for them. You would have to mod the PCB like crazy for any more than two motors. Maybe get two PCBs, double batteries, and four motors: like two cars, all in one chasis! Ha ha I'm crazy.
Old 04-14-2003, 04:17 PM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
That's the way I was gonna do my awd monster truck. I was gonna put gears on all fours and a motor for each gear. The only things keeping me back are a lack of time and the transfer gear problem up front.
____________________
Meh.
Old 04-14-2003, 04:30 PM
BillyP
Whoa that would have MONSTER torque!
Oops I meant "What a waste of POWER!" ...unless you get one of those 14-tooth pinion gears on every single motor!
Old 04-14-2003, 04:36 PM
sessiz10's Avatar
Told ya.
Waste of power?
What do ya mean billy?
Meh.
Old 04-14-2003, 04:43 PM
BillyP
I mean SPEED rules! If your car has any torque/acceleration at all, that's a bad thing. That means you have to use a much lower gear ratio! Like, approaching 1:1! (which would work with four motors!)
Old 04-14-2003, 08:30 PM
BabyKiller's Avatar
and i thought i was being origanal for once
+ (4.8v)
Old 04-14-2003, 09:17 PM
sessiz10's Avatar
Told ya.
Baby killer it was an original thought seeing as I haven't seen it posted anywhere. Just becuase I and probably a multitude of others have thought the same thing doesn't lessen your idea in anyway.
Okay billy, I disagree but thanks for your input.
Meh.
Old 04-16-2003, 07:19 PM
BabyKiller's Avatar
... yeah but i thought this is somthing people wouldnt think of
+ (4.8v)
Old 04-19-2003, 09:34 PM
MrMikey83 MrMikey83 is offline
Send a message via AIM to MrMikey83
Your idea is unique, but kind of complicated. You would have to make a space and cut notches for the motor, mount a peg for the transfer gear and it would only drive one front wheel as I understand it.
The solution, just cut two cars in half and glue the rear ends together back to back. Then, reverse the polarity of the front drive system and connect it to the wires for the rear motor. No steering is possible at all with this way, but I guess that is what you were going for.....good for drag strips I guess and if cut right, should be perfectly aligned as the axles don't move.
Might need an extra battery or two, but most of you guys already have 2 or 3 in your cars anyway.
~Mike
Old 04-19-2003, 10:03 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
i have already suggested this idea, i also posted pics but i dont remember where it was, i have the pic i posted about 2 months ago if u dont believe me
Old 04-19-2003, 10:58 PM
Sorry Audi, just letting the guy know there might be an easier way to go about making his idea work.
~Mike
idea for battle feild! Comrade_Boris Combat Digi Q 10 11-02-2003 04:46 PM
New Idea Rubber Bumper!!! jaws Bit Char-G / MicroSizers 9 11-15-2002 12:05 PM
A unique idea. Ok a crazy one! Nightwing Bit Char-G / MicroSizers 9 10-27-2002 09:23 PM
What do you think about this track idea? sneuburg Bit Char-G / MicroSizers 1 09-08-2002 06:30 AM
