04-01-2003, 10:43 PM
4 Certs and Climbing
Dual Cell Improvement?
Well I did the dual cell mode (info @ http://foy.foy.com/minircmod/moddocs...attinstruc.htm) very nicely written . Now I did use 2 batteries from a clone, so that may have made a difference, but as far as I can tell there was no real improvement, are the perfection 3.8's not good for this kind of mod? or did I do it wrong. I followed the instruckins word for wod, but one never knows. maybe I am expecting to much from these little buggers..
Shen Qui Wei - Honda Civic ---RIP
R/C Chassis - Nissan Gloria--- going Strong
MS - Honda 2000--- in process....
04-01-2003, 11:04 PM
Blitzer Sonic
You probably switched one of the batteries around. You want the batteries in series and not parallel. The wires in your is probably positive to positive and negative to negative. What you want is positive to negative to positive to negative. That is series.
04-01-2003, 11:24 PM
well I checked everthing, it all looks good, the only thing I can think of is that they are not a matched set .
04-01-2003, 11:31 PM
Blitzer Sonic
Is the insulator to keep the negative end of the first battery from touching the contact there? That is necessary. Even the smallest amount of it touching the metal contact can make it run at normal speed.
04-02-2003, 12:16 AM
Thanks for the help Zephyranthes , I took everything apart and did it over.. and DAMN! this thing is fast.....,
04-02-2003, 11:11 AM
