Go Back   TinyRC.com > 1/43 and Smaller > Epoch RC1/43 Indoor Racer > Epoch RC1/43
Old 01-31-2003, 10:49 AM
rmelancon
Using peak charger for Epoch, what is a good cutoff?
I'm cycling some of my cars whose runtimes are getting really short and I'm using a peak charger. Wanted to know if anyone knew the best setting for Delta Peak. I've been trying 15mv and it seems it false peaks sometimes.
Thanks,
Robb
Old 02-02-2003, 01:13 PM
gertman's Avatar
gertman gertman is offline
How many amps are u charging at?
-Engineering Manager
Old 02-02-2003, 02:29 PM
rmelancon
I tried 100ma, 200ma, 300ma and a few other settings. I know the transformer that Epoch sells charge at around 750 but I wanted to slow charge the cells in an attempt to "condition" them.
Should the Delta Peak change depending on amp rate?
Old 02-02-2003, 11:50 PM
gertman's Avatar
I am sorry, I really don't know. I do know that the Epoch charger is just a timer.
Sorry I can't be of more help.
Old 02-20-2003, 07:59 PM
slagrec1 slagrec1 is offline
We're using Duratrax Pirahna digital peak chargers and experiencing similar results. The charger documentation recommends 8mv for NiMH (and only 6mv for NiCD).
Have you tried a 2x discharge/recharge cycle?
Old 02-28-2003, 11:32 PM
blind's Avatar
blind blind is offline
None Better
the delta cutoff should be 7mv * the number of cells for NiMH batteries.
the epoch has what...3 cells? set it to 20mv if you can (I dont think the superbrain is all that adjustable, so you can't do 21mv)
DuraTrax AC/DC Piranha Digital Peak Charger NiCd/NiMH? mcharles13 Bit Char-G / MicroSizers 2 01-21-2003 06:56 PM
Peak Charger/seperate Charger bitchargen Bit Char-G / MicroSizers 0 01-06-2003 08:17 PM
hey tiny! peak charger?! mcharles13 Bit Char-G / MicroSizers 1 01-06-2003 09:46 AM
Peak Charger? vwarner Bit Char-G / MicroSizers 0 11-05-2002 05:24 PM
