Old 10-14-2002, 12:47 AM
SlackerZ's Avatar
SlackerZ SlackerZ is offline
Question lithium bats in controller
I didn't have any AA bats but a 3.6v lithium battery was on hand so I put it in the controller just to see what will happen. I've got a zz but this is my first micro and I don't know if what I'm seeing is unusual. Sometimes my charging led will shine brightly when I push down on the car and other times it will broad cast an average glow regardless of how hard I push or wiggle the car when on the charger. Its my first micro so it seems as fast as everyone says but the run time is about 1.5 minutes...is that short for a non zz? I assumed lithium would be superior to alkaline and the box specified it only because someone may use cheap non alkaline with poor results.
slackerZ
Old 10-14-2002, 12:52 AM
Nightwing Nightwing is offline
Bus Driver!
I know the ZZ take a lot of current. What is the current rating on that bat you are using?
Old 10-14-2002, 09:38 AM
shred shred is offline
shredding the masses
I took the batt out of my zz and put it in the micro.
The car seems more responsive but the run time is shorter.
Should I double charge???
Old 10-14-2002, 02:11 PM
Bus Driver!
Could be its can not produce enough current to charge the battery.
Have you tried a regular set of battries?
Old 10-14-2002, 06:00 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
i use the AA Energizer "E2" lithium batteries in my controler all the time..they are only 1.5V
Old 10-15-2002, 01:20 AM
Bus Driver!
From ther site the AA Lithium can handle up to a max of 2amps and discharge of 1.5amps looks good.
Cant post the direct link but just got to http://data.energizer.com/
and follow the links.
Old 10-15-2002, 05:18 AM
SlackerZ's Avatar
When charging the regular AA bats the controller always provides a brightly glowing led compared to the 1/2AA lithium. The lithium is to big to fit under the body or in the chassis so I've got no practical use for it...dang
-SlackerZ
Old 10-15-2002, 09:01 AM
Bus Driver!
Excuse me....
Its sounded like you were recharging the 1/2 AA lithium. Could be me. Its 5am and been working an all nighter.
If the single lithium battery does not glow or is very dim the 1/2 AA battery even at 3.0 volts is not producing enough to run the charge side. Could run the transmitter side but not enough for the critical side.
From looking at the Everready site, which ever of the two they list, it look like burst current for a few seconds and its spect to drop to 2v at 800ma which may be barelly enough to do the job.
Use Alk battries. If you substitue for them you need to match voltage levels and current draw.
2 std size AA Lithium can do it but not one of these small one cell 3v ones. They have a temp current limited built in.
PS: If that the same battery in your picture, that looks like one you would use to power the clock/cmos in a computer. Those are designed for low sustain current draws while this is a high current draw application. The circuity could go to 5v max of the TX-2 chip. The circuity is designed for 3v and drops when charging.
Overview On Lithium Ion Batteries moebrown20 XMODS Mods and Projects 19 05-02-2005 09:00 PM
Controller trouble... Sleeping911 ZipZaps 0 06-25-2004 12:33 AM
Proportional Controller EMULATOR ph2t Bit Science 88 01-21-2004 05:12 PM
Sucky Booster Controller aballen Bit Char-G Mods and Projects 3 09-28-2002 06:19 PM
