11-26-2003, 11:43 AM
Vaseline?
I seem to be running out of the gear grease that comes with the AWD kit. Would it be okay to use vaseline instead? What else would be good as gear grease?
11-26-2003, 12:20 PM
2Fast4U
I use no gear grease at all and even degreased my bearings. Degreasing the bearings is a huge speed improvemnt.
11-26-2003, 12:23 PM
0reZepyT
yeah, use somethign like goo-gone and get rid of all the grease in teh bearings and use a motor oil from a hobby store
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
11-26-2003, 01:03 PM
2Fast4U
I soaked the bearing for a few hours in a solvent (STP fuel injector cleaner) and then sprayed them out with RC motor spray to get rid of any remaining grease. I tested each one to make sure it spun free. The difference is night and day. I then installed the bearings dry without adding any lube at all. This way no dirt will stick to the exposed races and slow them down.
11-26-2003, 01:37 PM
sleeper mall civic
can someone post how u do all this stuff
douglascounty!!!
11-26-2003, 02:53 PM
2Fast4U
Here's how you degrease the XMODS bearings:
1. Wear gloves and eye protection!
2. Work in well-ventilated area!
3. Soak the bearings in STP Fuel Injector Cleaner. For best results, place the bearings in a small mesh parts tray in the container they're soaking in. The STP cleaner will dissolve the grease.
4. Towel dry the bearings and then spray each with RC motor spray.
5. Test each bearing by placing it over the tip of a pencil and spinning it. If they don't spin completely free, keep spraying them with motor cleaner. You might have to soak some in motor spray to get them perfectly free.
6. Don't add any oil and install as normal.
7. Enjoy the huge speed increase.
11-26-2003, 06:21 PM
You guys can also use Teflon or a dry lube. I wouldn't risk it on bearings, but I've use it on my suspension moving parts in light coats and it hasn't attracted any dust. I suppose it you were careful it may work in bushings. Graphite is another alternative, but I'd research that. I think it has mixed results.
What goat?
11-26-2003, 08:15 PM
u could also use graphite or maybe trailer hitch lubricate
11-26-2003, 09:15 PM
sleeper mall civic
hey thanks for the steps man it really help me
douglascounty!!!
11-27-2003, 05:36 PM
so use a dry lube like graphite and can i degrease them with Brake Cleaner?
11-27-2003, 05:56 PM
I don't think degreaser will remove graphite. An air-gun is probably all you need. Graphite is pretty much a smooth, soft forming powder. You can buy it at a hobby store, I think they use it for locks. Degreaser might be needed for white lithium and maybe teflon lubes. I don't think degreasers will be necesary unless you over-apply something like teflon and it binds something up. Degreasing is usually to clean off and relube a part if needed. The purpose is to get heavy greases and oils, that attract dirt and over-time start to lose efficiancy.
What goat?
11-27-2003, 06:23 PM
ied just soak the bearings in WD-40 <----best lube EVER
then pull them out ab dry them off with a paper towel
gettin them as dry as possible so no dirt sticks to them
11-27-2003, 06:27 PM
WD40 should be ok for the open bearings but I'd keep it away from most other moving parts. I believe they work against sealed bearings.
What goat?
11-27-2003, 08:44 PM
if one side of the bearing is open an one is sealed just soak them in WD-40 an when installing them point the open ends of the bearings toward each other
11-27-2003, 08:55 PM
is this good for stock bearings also or are they ungreased? How do u get to them?
Project Supra:
97 Supra
Black, Red hood
Mountain Dew skid plate
Custom Spinbrush Motor (11T/blue gear)
Custom 5th Cell System (9V)
Stock tires, superglued (didnt help)
Light kit
Wild body kit
more soon
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
vaseline good for gears?
Daazndood |
XMODS Parts and Hop-Ups |
26 |
01-02-2004 11:16 PM |
