05-11-2004, 10:07 PM
6 cell help needed
hi i just did a 6 cell mod. with xspeed 11 tooth and blue gear. it seems that i have lost alot of tourqe. cant do donuts on my kitchen floor anymore  . and everythign gets really hot. the batteries and the under body. could i have burnt any esc components. would a fet upgrade help thanks. but i clocked 32 kmh ~19.88MPH. and i am still waiting for my motor that i order should be running ~30mph then.
05-13-2004, 07:17 PM
I make great sandwiches
maybe your motor quit on you? the 11 tooth motor does not have much torque as it is. but with the 6th cell, it should have been up more 'cause of the more power to the motor. the only probs. i have with my 6th cell is i ripped my cup joints, and some range lost (like 3 feet less).
you can do, run the 6 cells without the body. BUT BE SURE NOT HIT ANYTHING. If the motor still gets, hotter that usual, you have a problem. check you connections, and so forth.
-shiporu
btw, your are using the heaksink right?
My Xmod:
now has Tiny Rc parts and schools everyone here!!!
05-16-2004, 11:22 AM
5Zigen
it may be one of the battery wires.
check to see if they are touching the motor.
since the motor makes enough heat to melt off the plastic from the wires.
use the tihings that hold the wires on the batt packs.
it happened to me.
Try And Sleep Now.
DRIFT my ANTI-rice
05-17-2004, 08:18 AM
You have a battery shorted or loosly connected.
It could also be how tight you got the motor screwed down. Loosen up the motor mounts so that the pinion and bevel don't mesh so hard. Without power to the car, try spinning the wheels and pinion with your fingers and see if you can sense any unnecessary drag.
Sorry, no vids for now.
05-21-2004, 05:48 PM
It's Really Fast!
I've had some heat problems with my 6 celled RSX. Get the 2 extra cells away from the motor, say like in the bumper, and it will keep it cooler. Put a torquier gear on it.
Project Bad Brushless:
Just say no to giant sigs.
