Old 04-01-2003, 10:43 PM
Darius2250's Avatar
Darius2250 Darius2250 is offline
4 Certs and Climbing
Dual Cell Improvement?
Well I did the dual cell mode (info @ http://foy.foy.com/minircmod/moddocs...attinstruc.htm) very nicely written . Now I did use 2 batteries from a clone, so that may have made a difference, but as far as I can tell there was no real improvement, are the perfection 3.8's not good for this kind of mod? or did I do it wrong. I followed the instruckins word for wod, but one never knows. maybe I am expecting to much from these little buggers..
Shen Qui Wei - Honda Civic ---RIP
R/C Chassis - Nissan Gloria--- going Strong
MS - Honda 2000--- in process....
Old 04-01-2003, 11:04 PM
Zephyranthes's Avatar
Blitzer Sonic
You probably switched one of the batteries around. You want the batteries in series and not parallel. The wires in your is probably positive to positive and negative to negative. What you want is positive to negative to positive to negative. That is series.
Old 04-01-2003, 11:24 PM
Darius2250's Avatar
well I checked everthing, it all looks good, the only thing I can think of is that they are not a matched set .
Old 04-01-2003, 11:31 PM
Blitzer Sonic
Is the insulator to keep the negative end of the first battery from touching the contact there? That is necessary. Even the smallest amount of it touching the metal contact can make it run at normal speed.
Old 04-02-2003, 12:16 AM
Darius2250's Avatar
Thanks for the help Zephyranthes , I took everything apart and did it over.. and DAMN! this thing is fast.....,
Old 04-02-2003, 11:11 AM
Darius2250's Avatar
ok Just thought I would give out the update on this dual cell mod, and what I used and yadda yadda yadda. Well first I started with an R/C Chassis(some clone I found in the mall, didn't want to hack up my bit (yet)). it has some steering issues, like all the sudden it will turn to the right and no matter how much I trim it still pulls to the right, I recentered the magnent still no go... but anyways it was a good test car, so I got it all done, it wheelies, flips over and generaly has no control(that part hasn't changed)it's got a 2.6 in it and clone gears so I don't know the ratio. I hope my bit with a perfection 3.8 has better control.
which dual cell should i do, laymans, external, internal etc eman1 Bit Char-G / MicroSizers 11 09-02-2003 07:42 PM
Laymans dual cell vs. traditional dual cell Zephyranthes Bit Char-G Mods and Projects 6 02-18-2003 06:12 PM
Dual cell mod ( will 2 - 50 mah's achieve + speed?) Suntzu28 ZipZaps 7 01-11-2003 09:57 AM
Dual cell mod and discharge problem (cell reversal). kenny_dilger Bit Char-G / MicroSizers 1 12-17-2002 10:23 PM
