03-30-2003, 04:01 PM
27,35,45,57 Interference?
I own two MS at 27 and 49 frequency and two Shen qi wei clones at 35 and 45 frequency.
I thought I could drive them all at the same time, but the 35hz SQW controller is able to control the 27hz MS! (just turning slightly)
I was wondering if this is just because the Shenqiwei is controller is made poorly... and if anyone has experienced this problem with actual Bit Char-G cars: e.g. If I buy a 35 and 57 Bit will I be able to drive the 4 MS/Bit at the same time w/o interference? I would find it hard to race if I can sabotage my opponents. :]
Anyhow, I have yet to try the 45hz SQW with my 49hz MS but I am guessing they are so close that there WILL be interference.
I have heard in europe they also use a 40hz frequency?
Has anyone tested this with a 35hz or 49hz Bit? Are they able to drive w/o interference?
Thanks!
03-30-2003, 04:02 PM
Argh! My friend just came back from London for spring break. I should have asked him if he saw any Bits!
03-31-2003, 09:42 AM
State Property
..i have ran 27 ,35 ,45 ,49 and 57mhz all at the same time and no interferience..
03-31-2003, 09:51 AM
same here. sometimes different brands dont like eachother.
microsizers controllers are the crappy ones actually. those round clone controllers get tons better range. clone cars are usually poorer quality than bits but the tomy electronics are horrible.
03-31-2003, 01:34 PM
Just got my 40 Mhz Compact Char-G
I run all 6 frequencies. I don't get interference with my legit bits (Char-G, Compact Char-G, Microsizer); actually, they do interfere a little if one controller is too close to a different car (~1ft or less), but the 27 Mhz MS drives the 35 Mhz LXX booster, and kills my 57 Mhz LXX booster. I think you have to stay within brands or just get lucky.
03-31-2003, 02:01 PM
yupp
